2.0 tfsi - first things
hi all,
I should be getting my 2007  Octavia VRS  2.0 TFSI  this week, and Im eagar to get stuck into sorting out common problems before they arise.
I will be doing my own servicing on the car,  and I will be doing that as a first point of call. including a full inspection of the radius arms and suspension.
I just wanted to know if there is anything I should be looking at, like the diverter valve, and isnt there a cam on the fuel pump that is prone to going wrong ?
Is there anything else I need to look at ??
all comments welcome please.
Yes the original diverter valve is prone to splitting, there is a revision one from Skoda that is fine even when mapped and costs around £50 pointless getting a forge one . See if its had the recall for coil packs done on it as well . I had my air con condensor fail and the teeves 60 brake sensor . Bushes are prone to splitting too , and welcome to Briskoda
Welcome aboard... I think Alan has covered the main items there.... nice one!
All the maintenance checks... then a remap works very well indeed :happy:  ;)  :thumbup:
Definately worth changing the cam follower, if this wears excessively, it can damage the camshaft. The follower itself is only about £30.
All the above, plus I would recommend checking the PCV system and looking to update or delete ( R-Tech full PCV delete is meant to be very good, I have the Forge delete kit myself)
There's a guide to checking which revision camshaft you have fitted, be worth doing that as well.
This for the info guys ... I'll be ripping into it the weekend
Sent from my SM-G920F using Tapatalk
