Engine problems with the felicia
Hi
i've been having problems with the felicia recently. when im driving it starts to jerk every so often as if its struggling to keep moving. its fine a lot of the time but it just happens for a second or so. does anyone know what the problem might be and how to fix it? by the way its the 1.3LXi Plus (SPI)
thanks in advance
you looked at the spark plugs? make sure they are all evenly used?
fuel filter? shatty fuel? up it a grade to 95 or 98? or down it a grade if you been on 98?
if not injectors perhaps? never had an issue with my 95 lxi SPi
will be the rotor arm change it for the black bosch one from your dealers
