Space Saver Wheel
  • Replies 50
  • Views 13.4k
  • If you had chosen spare wheel option at time of order it would only have cost £100 complete.
  • cant you put together a quick and dirty kit as follows for about £60 ?........   Spare Wheel - £30 Tyre - source a second hand one - £10? Jack £8.50 Wrench - £7.50
  • i think if u have the VBF then yes as it wont matter.   Im reading this as if you dont have the VBF, you need a 6.5" width wheel to avoid it lifting the boot floor (as a 7" would)
Sorry I was on the mobile when I posted so did not click on your link.
Yes,  205/55/16” is the std size spare for all but the 280.
205 = 205mm IIRC they are fitted on a 7” rim, the boot floor actually touches the sidewall of a 205/55/16” spare.
Hi
I am the proud owner of a 2.0 Diesel SE Business Estate, delivered in October.
Just realised that it comes with a compressor and some kind of goo to get me home in the event of a puncture.
I contacted Skoda regarding a space saver and was quoted the following:-
£254 inc vat for 16 inch steel wheel and tool kit.
£417 for space saver and tool kit.
Obviously they seem very overpriced.
Does anyone know which other space savers from the VAG range will fit?
I will look to get a second hand one via ebay.
Regards
        I think the Skoda website  or those of " cheaper suppliers " of new cars quote £100 for  the  spare wheel of the smaller dimension/ get home version so I would check on that and take Skoda to task with their outrageous  quotes.  I think any VAG  wheel of similar size would fit?.  But one interesting  point does arise in that when  one opts for a spare wheel  in lieu of the gunge machine, it seems NOT to come automatically with the wheel removal tackle, presumably the wheel brace AND JACK??.  I paid the £100  for a spare wheel as driving without one would frighten me to death ( gunge can't cope with splits ) and it came with brace and jack,which I must confess I assume comes with a new car anyway?. They'll want extra for the bluddy air in the tyres next. Btw,make sure  your wheel well is big enough to accommodate the wheel you intend buying, and that is assuming  your vehicle has a wheel well. They may have wanted extra for one !
jesus.
Right so is the correct SPARE wheel the 6.5" one from the Octavia? (so it fits under the boot floor)
Sorry if I've missed this - but will a 16" wheel with 205 width tyre fit under the variable boot floor in the estate ?
We've got the VBF and skinny space saver at the moment. Wouldn't mind changing for more of a normal wheel/tyre size if possible.
Yes as the VBF sits above the std boot carpet.
The width of the wheel will make no difference as the tyre is wider than even the 7” rim
OK, so forgetting about the rim size, what's the fattest tyre that will fit in a non VBF? 195? 180?
205 ... which is what is supplied to cars that can run 16” wheels (non 280) and doesn’t have the VBF.
ahhh!
so will a 16" wheel, either 6.5" or 7" wide, with 205 fit under the normal boot floor without sticking up?!?
Not sure how many ways I can say this
YES a 205/55/16" will fit under the boot floor even on a 7" rim.
Edited by Gizmo68
I have a full size 16" spare for my octy mk2 fl, will this fit the car? Same bolt pattern etc
Edited by nicowalker85
The wheel will fit perfectly... the jack however is different.
Ive ordered the space saver anyway. I shall remove the spare from the octy though!
  • 5 months later...
I am buying a Superb demonstrator which has 19" wheels. Currently it has only the puncture repair kit but I would like to add a spare wheel. Does the fact that the original wheels are 19" make this a problem. Must I get it through a dealer or are there third party suppliers?
Remember the above is just the toolkit its not the Spare Wheel and tyre as well!
The tyre size is 125/70 R18 and mine is a Continental Spacesaver
http://www.ebay.co.uk/itm/SKODA-Yeti-SUPERB-Octavia-Space-Saver-Spare-Wheel-Tyre-18-Genuine-Jack-Brace-/191754934234
http://www.ebay.co.uk/itm/Volkswagon-Passat-Superb-2015-space-saver-spare-wheel-tool-kit-T125-70-R18-99M-/111995661572?hash=item1a13762d04:g:8sQAAOSwQoFWQIhU
Edited by Prykey
Thanks Samo and Prykey. Since I am ignorant of such things, does it not matter that the spare is an 18" rim compared to 19" rims as fitted?
If you got the item from the factory as part of your order it would be an 18" as linked to above, as it's a temporary spare you are restricted to what speed you can go, I think that its 50mph.
It's only really meant to get you somewhere so that you can get your original tyre repaired or replaced.
What engine?
Only the 280 (and 220 IIRC) petrol engine cars get the 125/70/18" skinny space saver, the rest get 205/55/16"
My 190 TDi came with 19's and I have a 16" spare.
Don't forget the tools as well, (jack brace etc...)
Gizmo, it's an L&K 190 TDi estate so it sounds like the 16" spare. The dealer has quoted £345 but Skaodaparts.com have the wheel and tools at just under £180
the car buy the 16 inch wheel for £35 and a tyre for as cheap as you dare.
just another thought, and I realise that this would be vastly more expensive (but possibly worth it), does anyone know if the well in the Superb III estate will take a full size 19" Phoenix wheel?
