P2196 fault code - engine light -
Hi all -
need some help?
I changed the lambda sensor about a month ago and now I've had the engine light come on - Its the same code as before.
So either new sensor is faulty or its another sensor - anyone had similar problem?
It doesn't affect the performance of the car in any way, the code can be cleared with my basic OBD reader and it'll come back depending on how long the car is driven.
Engine
Part #: 03L906022BK
Component: R4 2,0L EDC G000
Coding: 78 (decimal)
Fault codes:
P2196 O2 Sensor Signal Bank 1 Sensor 1, Biased / Stuck Ri
Thanks I hadn't found either links when searching, I'm going to try and test them.
