AC Ventylation problem
Hi,
I was searching a lot in this forum and on other website. Unfortunately I didn't find any solution for my problem. I have Skoda Fabia Combi 1.4 TDI 80HP. Few weeks ago I've bought VAG cable and get error with AC:
 Faults Found:
00819 -  High Pressure Sensor (G65)
            07-00 -  Signal too Low
            31-10 -  Open or Short to Ground - Intermittent
I refill gas in my AC and now AC is working. I can set temperature correctly and I don't see any problems.
Unfortunately when I don't want to use AC I can't set temperature. I have only cold or hot air.
Currently I don't get any errors with VAG cable, so I'm not sure what should I do.
At the beggining I thought that it might be problem with panel. But now when AC is working correctly I'm nor sure about this. What do you think ?
I've found on some SKODA forum that if I will have some problem with 'air engines' I should get some errors with VAG.
Please share with me you suggestion.
Thanks.
Sławek
