Battery
What tools Do I need to remove bat and where are the bolts I need to undo it cheers ?
You will need a 10mm wrench.
And a 13mm socket on a long extension to unbolt the battery from its carrier - this is low down on the front of the battery, plus probably a long thin screwdriver to unclip the plastic battery cover.
I've always used only a 10mm socket .. and I'm kind of good at this sport .. since I have a 1amp something slowly killing my battery lol.
  • Sponsor
You must be missing the clamp that holds the front edge of the battery?
Items 7/8 here.
Edited by Wino
Mine does't have one..
  • Sponsor
I think it should have. A battery is heavy, so will carry a dangerous amount of momentum in a crash situation, becoming a projectile, unless secured well to the car.
Uhm I guess mine had a weight reduction in the past. :)
Is it stable and secure? I'm told that an unsecure battery can be a fine-able offence. I could have been told nonsense.
To the OP - you'll need an extension section as posters have mentioned above, to get to the hard to reach retaining clip.
JRJG
Edited by Jrjg
I don't think mine has anything holding it down either I just wiggled it out. it did however have a lip in the bottom of the battery tray holding it somewhat securely
MOT fail if spotted. However the cover tray would prevent getting onto the battery to check it.
  • Sponsor
Clamp and clamp bolt visible outside box though, absence would=insecure mounting I'd've thought.
You can't really see them on a vRS as the battery is quite far forward.
  • Sponsor
Ah, fair enough.
I'd have thought a shake of battery would show that. But then again, I've had an MOT tester tell me that I had a corroded heat shield on rear box on exhaust. Couple of years later, (different tester,and no exhaust advisories), had problems with low piece of exhaust . Thinking new box needed I headed to exhaust place, for the exhaust man( looked quite fresh :D ) to tell me that VAG use double skinned exhaust boxes. Soe times I wonder if MOT blokes look at cars through £ tinted (safety)specs.
If you have the full battery cover you can't see it to shake it. The cover/tray will be secure as it has its own retaining bolts.
The battery tray clamp was missing off mine when I got the car. I made one out of a piece of scrap steel. Don't like the battery not being secured.
Edited by TMB
