Mk2 Octavia vRS rear Calipers and both ARBs
Just having a sort out in the house, I've got both rear Calipers and carriers off my Mk2 Pre-FL vRS, both in need of a full refurb (paint and seals). Asking £50 plus post or send a courier.
Also both ARBs from my Mk2. The rear still has a drop link attached that I can't remove and will probably need cutting off. Also asking £50 for these plus post or send a courier (they are relatively heavy, the front ARB particularly).
Back to the top.
Hup.
Regarding the ARB's, what's the different compared to a standard Octavia?
Are they the same size? Do pre F/L fit F/L?
G
I don't know the difference vs a standard Octavia, but I imagine they are larger and stiffer. I was surprised at how big (diameter) the front bar is. They should fit all Mk2 Octavias, both pre and post FL except 4x4 models (I believe the front is different on a 4x4).
If someone can confirm if they are larger & stiffer and would be a decent upgrade from a non VRS model I'll have both off your hands. Would need them delivered to Glasgow however?
G
