Front Door Rivets....
After replacing my window regulator last week (a horrible affair), I used my rivets on the panel.
Today, the window got stuck halfway and then disappeared, so something is not right.
I want to use the right rivets this time, but could do with getting them today. I can see they are N91078801 but nowhere tells me what size they are.
Any hints?
Cheers.
  • Sponsor
6.4mm dia. Can measure length in minute or 5.
You will also need to know at what torque the rivet breaks off (the actual name of the figure escapes me at the moment). Not all rivets are equal so it's probably worth grabbing some genuine ones. Are you replacing the whole panel, just the regulator or just the repair kit?
Also... If your using genuine rivets you might need a larger rivet attachment.
  • Sponsor
Here you go.
Shaft (steel) 3.65mm dia. (bigger than many tools take)
Head dia. 11mm
Length (from under head to end of ball) 14mm
Rivet (aluminium) dia 6.4mm
It kept moving around which makes my picture less clear!
Cheers for the replies, guys.
It was just the whole panel the other week, the motor itself was fine.
Window was working okay, then last night got stuck at halfway, went back to the top and then in five minutes time dropped and disappeared.
Need to take it apart to see what the problem is, but wanted to try and sort it quickly. Nearest Skoda garage is about 40 mins walk, but not sure they are open today so wanted a back-up if I could get them from Halfords or similar.
Here you go.
Head dia. 11mm
This is perfect, cheers! :D
They won't be open on a Sunday no.
As said though you want the right ones or they won't have the correct clamping force. If the window has dropped down either the regulator has broken or the window has come out of the clamps somehow.
Here you go.
Head dia. 11mm
That should be pinned for future use! So many people ask about them.
Yeah, realised this after I had rang them! lol
Hoping it has just come out of the clamps, will find out in the coming days.
Any solutions other than bin/recycling bags sellotaped to the window to keep out the wet?
Pull the glass up with your hands and wedge it shut with cardboard and tape.
Edited by hutchysrs50
I didnt use them tbh i just drilled holes to the side of where they was on the door card and used smaller ones but kept with steel rivits and silicone. Works a treat
Glass is right inside the door, I am awful with any physical labour so didn't want to take the card off.
Have made do with some handy tape, bin/recycling bags and card.
Anyone know what size screws/ bolts attach the actual mechanism to the door.
I've lost them and dont know what size they are.
Fitted the new regulator but need to finish it off now. Been few months now and its getting irritating.
Sent from my SM-G920F using Tapatalk
Which bolts do you mean? The window regulator is riveted to the carrier with pop rivets.
Edited by TMB
I assume he means the 3 large Philips head screws, same as 13mm bolts I think and the 3 small torx screw along the bottom.
You mean for the door card?
Basically yeah, the rest is riveted on unless he's one of the lucky ones where it's all bolted on before they changed to rivets
Small pilot hole and then a self tapper next to where the original rivets should be does the trick fine. Also you can then get the panel off again without all that faff...
Thanks for the replys.
The rivets i bought were too thin. I got them from skoda parts website...but my mechanic just drilled a seperate hole for the rivets i had to make them fit.
Here's a pic if what i mean.
(They were too thin)
Its the 3 screws im after. That connect the mechanism to the panel.
I wonder if water will get past all the holes... will find out i suppose!
you mean the three torx screws that hold the windor motor to the regulator?
Looks like you bought the rivets for riveting the regulator to the door carrier (N90765701) rather than the 6.4mm ones (N91078801) for mounting carrier to door.
Edited by TMB
Ye i purchased the ones ending in 701
Took pics of the screws.
