Front Door Rivets....
Recommended Posts
These three are what hold the door card to the door, the three Philips screws similar thread to 13mm bolts I belive.
These three are what hold the window motor to the carrier by the three black lugs sticking out, 3 torx screws with sort of wood screw threads.
  • Like 1
Link to comment
Share on other sites
  • 4 years later...
10 hours ago, Mobear said:
Hi does anyone know what length of the M10 bolts are thanks in advance
14mm.
Part number N 904 911 01
  • Thanks 1
Link to comment
A very good idea is to install rivnuts and bolts instead of the rivets. Makes life easier when dealing with broken window holders, door lock, damaged elec wires in the rubber below...i experienced it all
  • Thanks 1
Link to comment
Just drill the rivets out if you need to, they're cheap and easy to replace if you need to get in there again. Using bolts is much more expensive, a rivnut tool costs far more than a plain riveter and the rivnuts cost more than rivets, it doesn't make any sense.
Link to comment
Just depends if you can get the rivnuts flush, if they aren't it's going to leak.
Link to comment
If you have at hand kind of rivet gun which is able to use this big rivets than it is easy.
If not, you can install rivnuts with 2 spanners, a bolt and few nuts (you can find online how ti do it).
I dont have any leaks, used it on 3 doors.
Link to comment
Can you tell me what size you used please
Link to comment
3 hours ago, pavinjo said:
Sorry, i checked but no any spare to measure. Should be about 30-40mm, sorry not to be able to tell you precisely
No problem pavinjo. Im just going to get mixed ones and see which fit I will be making a guide so other people can follow as not much on this subject
Link to comment
  • 1 year later...
Did you ever make a guide for how to use rivnuts on the door carrier? Want to get my door apart this weekend but struggling to get suitable rivets in time
Link to comment
Sorry never had time but this what I bought link at the bottom.
just go on YouTube to show you how you remove door card.
once off drill old rivets out
install rivnuts and get the same size bolts for the rivnuts you installed
Done.
I say it take you 30 mins a door to do
https://www.ebay.co.uk/itm/Rivet-Nut-Gun-Hand-Blind-Riveter-60-150PC-Mandrel-Repair-Tool-Set-Metric-M3-M12-/203519533377?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l6249&mkrid=710-127635-2958-0
Link to comment
Done.
Great stuff thanks. Now its just to get the door open in the first place in order to figure out whats wrong!
Link to comment
I never had that problem do can't help but Check on YouTube plenty of videos showing how to open them as its a common problem
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
