Failed M.O.T due to heavey steering
well recently failed m.o.t on friday due to the steering being heavy when stationery, steering is as normal when driving but only seems to be heavy when parked up when the engine running or driving around 5 mpg round a bend it tends to really stiffen up..other than that the steering if completely fine
scan results below
Monday, 11 January 2016, 14:23:32:0
Chassis Type: 6Y - Skoda Fabia I
Scan: 01,02,03,08,09,15,17,19,25,37,44,46,55,56,76
Address 01: Engine       Labels: 038-906-019-ASZ.LBL
   Controller: 038 906 019 LA
   Component: 1,9l R4 EDC 0400SG  5266
   Coding: 00102
   Shop #: WSC 13765
   VCID: 61B52687F851
   TMBWU46Y443900634     SKZ7Z0C2044302
1 Fault Found:
17911 -  Load Signal from Alternator Term. DF: Implausible Signal
            P1503 - 35-00 -   -
Readiness: N/A
Address 03: ABS Brakes       Labels: 6Q0-907-37x-ABS.LBL
   Controller: 6Q0 907 379 H
   Component: ABS/ASR 5.7 FRONT   V30
   Coding: 00188
   Shop #: WSC 13765
   VCID: 42F7C90B5D97
No fault code found.
Address 08: Auto HVAC       Labels: 6Q0-820-045.LBL
   Controller: 6Y0 820 045
   Component: Klimaanlage        X0830
   VCID: F297D9CBADB7
6 Faults Found:
65535 -  Internal Control Module Memory Error
            00-00 -   -
01271 -  Positioning Motor for Temperature Flap (V68)
            30-10 -  Open or Short to Plus - Intermittent
01596 -  Motor for Outside/Recirculated Air Flap (V154)
            30-00 -  Open or Short to Plus
            41-10 -  Blocked or No Voltage - Intermittent
            29-10 -  Short to Ground - Intermittent
            28-10 -  Short to Plus - Intermittent
Address 09: Cent. Elect.       Labels: 6Qx-937-049-B.LBL
   Controller: 6Q1 937 049 C
   Component: 00 BN-SG.           1S33
   Coding: 00014
   Shop #: WSC 13765
   VCID: 3B09B4EF3A7D
5 Faults Found:
01598 -  Drive Battery Voltage
            07-10 -  Signal too Low - Intermittent
00511 -  Selector Lever (E313)
            49-00 -  No Communications
00778 -  Steering Angle Sensor (G85)
01324 -  Control Module for All Wheel Drive (J492)
01336 -  Data Bus for Comfort System
            80-00 -  Single-Wire Operation
Address 15: Airbags       Labels: 6Q0-909-605-VW5.LBL
   Controller: 1C0 909 601 A
   Component: 11 AIRBAG VW51      0008
   Coding: 12593
   Shop #: WSC 13765
   VCID: 1E4F5D7B89AF
Address 17: Instruments       Labels: 6Y0-920-xx0-17.LBL
   Controller: 6Y0 920 970 Su
   Component: KOMBI+WEGFAHRSP VDO V06
   Coding: 28401
   Shop #: WSC 13765
   VCID: D6DF855B211F
Address 19: CAN Gateway       Labels: 6N0-909-901-19.LBL
   Controller: 6N0 909 901
   Component: 31 GATEWAY  CAN    1S33
   Coding: 00014
   Shop #: WSC 13765
   VCID: F093D3C3A3BB
4 Faults Found:
Address 25: Immobilizer       Labels: None
   Controller: Bit teA dre ssu
   Component: e 17 eingeben
   VCID: CFD1703F1EC5
No Faults Found
  or DTCs not supported by controller
  or a communication error ocurred
Address 44: Steering Assist       Labels: None
   Controller: 6Q0 423 156 S
   Component: LenkhilfeTRW        V260
   Coding: 10120
   Shop #: WSC 13765
   VCID: 3FF1C0FF2E65
Address 46: Central Conv.       Labels: 6Q0-959-433.LBL
   Controller: 6Q0 959 433 E
   Component: 33 Komfortgerát     0002
   Coding: 00066
   Shop #: WSC 13765
   VCID: 3D0DBAF72469
2 Faults Found:
00849 -  S-contact at Ignition/Starter Switch (D)
            25-00 -  Unknown Switch Condition
End   --------------------------------------------------------------------------------------------------
could this be a possible broken wires / bad connection? when i click on the angle sensor messuring block it just reads 0 even if i turn left or right.
thanks for any help
edit: also is the coding for steering assist correct as i cannot adjust and save the steering weight it just goes back to 10120 no matter what digits get changed
   Coding: 10120
   Shop #: WSC 13765
   VCID: 3FF1C0FF2E65
Edited by KX250
You've got 2 faults pointing at the steering angle sensor, which will effectively disable the electric motor leaving you with no PAS. Also, I don't like the look of the alternator implausible value, so I'd check the voltage across the battery terminals with the engine idling since low voltage is known to have adverse effects on electric PAS.
The load signal wire failing is very common, plenty of threads on here. Failure leads to all kind of weird electrical gremlins. First thing, fix the load wire, clear the faults and see if steering returns to normal.
All those fault codes could have a single cause, the alternator load wire.
Thanks for the help, the only wire I have found damaged so far is the wire what plugs to the alternator, could this cause the problems with the steering?
I presume you mean the "Load sense" wire discussed above. If so, then yes that will stop the alternator charging, and kill the PAS motor to save electricity.
This!!
Also if you want to get rid of the selector lever and all wheel drive faults, which is equipment that your car doesn't have, refresh the gateway coding as in recode it with exactly the same coding it has now.
Lost count how many times we have posted that up lol
