Single Din to columbus....need help?
My missus bought me a Columbus for xmas, the previous owner of my car had fitted a single din stereo.  Just got round to buying a fascia for the dash, but the only problem is I'm trying to locate the right wires and block connector to plug columbus into my cars loom, can someone help me, if not I'm gonna sell the columbus and get a aftermarket stereo for it instead.
Edited by richl78
If you follow the after market stereo leads it should connect up to the original lead and all you need to do is to remove it and connect the original lead back to your Columbus. Try removing the top tray as well as it will give you better access of where the original lead connects up as it is probably hidden behind the dash.
Disconnected my single din, and the square black box doesn't match up with the columbus.
Pictures? The original may have been cut off and replaced...
