noisy after startup......and i'am getting worried
Hi
whilst my 1.2 TSI 60 plate yeti appears to be otherwise fine, upon start up its very nosiy (sounds like a diesal rattle) - this has been going on for some time - intially it was only noisy for the matter of a few seconds then suddenly would return to a normal engine note which is much quiter. Now its lasting for longer circa 30sec but i have just found out that if I turn the engine off after a few seconds then start up again the noise disappears or is much subdued. I've only done about 40K.
any ideas what might be causing it ? - hope its not anything major :sweat: - just recently had to fork out for new ignition coil and leads after breaking down with a misfire
thanks for your time
Hello darlo, and welcome to the Yeti site.
First, have you checked your oil level.
Second, when was your oil last changed.
When you start up, do you rev the engine? If so don't. Oil needs to circulate before you rev it.
Also when switching off, do not rev the engine, just switch off, at idle.
I say this as only yesterday I was in a car park & a driver revved his engine & turned off the ignition at the same time....why?
Edited by Carlo diesel
Welcome to the forum.
Maybe have a search for the Timing Chain / Tensioner Issues with 1.2 TSI engines,
the threads should be easy to find, it not only affects the Yeti but other Skoda Models.
Given the history of timing chain problems with 1.2 TSi engines of your vintage,  and as this could be a timing chain issue,  its very important that you get it looked at without delay.  The very last thing you want is for the timing chain to fail,  or jump a tooth, as this will wreck the engine.  If you've had it from new you will know whether modified timing components have been fitted... if you bought second hand then a Skoda dealer may be able to find out.  Either way it needs prompt action.
Both the number 3 high tension plug lead/coil
And
The timing chain were subject to a factory recall
Determine if both were done as, being an acknowledged fault, should still be arguable.
Out here, recalls are recorded on the lower A pillar driver's door hinge area.
Re the plug lead, ensure it is insulated and routed away from the turbo's heat.
Edited by Ryeman
Colin
We need a 'logarithm' that identifies
1.2
Timing chain
Plug/coil lead
With auto-generated recall note.
It seems that would eliminate so many repeat questions.
I think you mean algorithm.
Hi recently had 45 K service, reported some  concern's as you reported. 50.000 KM
+ Found that I had Major problems concerning fuel  Pump/electronics included within Tank.
Just out of Warranty . Previous  vehicles 2 diesel since 1980, nearly 1M kilos. no prob's.
Service Dept. were magic, but refused copies of electronic Diagnostics sent to VW Aus/Skoda.
have learn t that Info is Magic.
Is this or another Skoda Gate, my Snowman is Magic still.
Edited by Gobmax
Err yes ))))
