Let it snow let it snow let it snow
DPF cleaning £265
12573850_865334993579143_162690272337846
Huh? Has that all come out the exhaust? How's that work?
yeah, what's the story here.
Apart from what most mechanics tell you about the ERG and DPF, that you should drive the car at a constant high revs for a period, every now and then, which helps blow out the soot. Are they're diesel additives that you can add once a month or something to help?
so do they put the cleaner directly into the exhaust manifold? (sorry can't look at facebook!)
Or you could just remove both EGR & DPF........
G
G
which would be illegal and a MOT failure?
Tetraclean engine cleaner goes into the inlet, DPF cleaner looks like Mr Muscle.....wouldnt need to go through the engine
The readings before/after are impressive
Edited by lichfielddriver
Visual inspection..... If it's cut and welded it'll be fine
G
Currently, a gutted DPF will pass an MOT but this doesn't make it legal. If it becomes common enough, the MOT might change from a visual inspection only...
G
have u had it done?
So how do they get the dpf cleaner into the dpf? Up the exhaust?
I dont know.....why not ask em
07494 507637
When you remove the dpf the car smokes and smells , taxis tend to do it. How much is this procedure and what's that stuff that comes out of the exhaust
07494 507637
Oh, have you not had it done? Assumed you had...
have u had it done?
Previous Octavia had it done, faultless, in fact it ran better than before work was completed
G
Dont agree and I'm a taxi driver, my last Octavia had it done, no smoke, no smell. The car smells dreadful when it's on regen, remove the above and it no longer does this. Regarding smoke, again I disagree, but I had it done at a decent tuners, custom map, not your rubbish generic ones that are £150.
They don't fit them for fun , it doesn't matter who does the job , the particle filter is removed and you'll see smoke
Visual Inspection for UK MOT and you choose what you do.
Vehicle used for gain or reward and insured to carry paying passengers,
there are things to consider like valid insurance or you making it Void, but then that is a choice as well.
I had 2 cars done and regretted ot after as they stank . I think I'll try this the next time
https://www.youtube.com/watch?v=wiViPKIoG68
It follows the same principles as this. It uses a highly refined fuel, which is then atomised finer than normal diesel would be giving it a cleaner burn, this in turn burns of the carbon deposits in your engine and DPF.
Haven't had it done, but when the time comes I will be trying it first.
Edited by JamboDave
After how many miles this would be useful to have it done?
I think driving style counts more than mileage TBH
