Maf
I always leave the TB plugged in with the ignition on & something wedging the gas pedal down to fully open the TB flap, which makes it much easier for cleaning.
You don't actually need to reset/adapt the TB with VCDS/Vagcom if you unplug it as it will self align over a few driving cycles, but if you do unplug it's important not to start the engine untill the TB stops whistling { approx 30 secs) when reconnected & ignition on.
N.B. If you do unplug the TB don't force the flap open or you'll be buying a new unit £££££'s.
BTW Isopropal is fine for cleaning the MAF. If you do have to get a new MAF buy genuine only or you'll be buying twice.
Edited by pauldazzle
Great stuff.cheers mate
  • 3 months later...
I am having the same code, P0172. Did you finally sort it out?
I have already cleaned the TB and I removed the MAF today but I found a crack to what seems to be an insulating glue. Any ideas?
Edited by OCTAVIA_4X4_ABT
Good advice - I ended up buying twice.
I don't know how these sellers get away with bad MAFs on the market. So strict with MOT's but there is no regulation selling parts that don't work.
