Touch-Up Paint? Is There A Difference
Hi Folks
I'm in need of getting some touch-up paint, just for minor stone chips on the front bumper etc but one thing I would like to know! is there a difference between these 3 paints or do you think its just for image purposes ;)
http://www.ebay.co.uk/itm/331751771803?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.co.uk/itm/172067152700?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.co.uk/itm/151956544724?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Agreed. You seem to be overreading the difference in packaging a wee bit - they all have the same code. Beyond that, what can you possibly do (or anyone else advise) other than buy and try it :)
Edited by vRSAnt
Yeah they all have the same code etc that ain't what I'm thinking about? I was wondering if maybe one has a paint brush in the lid etc as oppose to just a pen touch-up or if there all the same regardless
Probably just used stock photos - one says the colour is ...... graphite. As long as the correct code is ordered I wouldn't worry.
One says touch up pen, one says paint, the third says pencil. probably all the same, and I've NEVER found one of these kits without a (rubbish) brush in the cap.
Which do you prefer, seeing the chips, or, slightly different coloured repairs, which will fade and probably blend-in after it's weathered a bit?
I prefer to do it properly if I can - limit the amount of paint going into the cavity, and blend it down if theres too much. Almost impossible with the standard brush as mentioned above, i.e. use something else.
a needle is good, or really fine artist brush.
  • Like 2
Received Race Blue Touch-up this morning in the post
Purchased from here:
http://m.ebay.co.uk/itm/172067152700?_trksid=p2060353.m1438.l2649&_mwBanner=1
Has a brush in the lid but think I will use as suggested above, a little fine artist brush, other than that the colour match looks pretty much spot on.
May even be worth transferring a blob onto a bit of card or plastic to work from and then tightening the lid quick ?
As obviously with all the time and care needed to focus, all the solvents are disappearing and before you know it you have a nice solid lump of unusable, unrunny paint globule !
- Actually takes a bit longer than that, but just thinking sensibly as theres nothing more annoying than having a full, but solid, paint pen. Usually happens to me because of a snapped overtightened case but can happen through keeping the lid off too often.
Edited by vRSAnt
You could use cellulose putty, to fill chip up level, then rub down, spray area with undercoat, then top coat finish with clear lacquer for a more professional finish?
Chips are a beast to camouflage, just by painting over, as they leave uneven levels which casts shadows and highlight repaired area.
