Octavia 1.9 TDI 4x4 part codes problem
I have a 2006 Octavia 2 1.9 TDI 4x4 and I want to refurbish the rear brakes.
Unfortunately the 4x4 doesn't seem to appear in Haynes manuals or any other manuals that I can find.
It is NOT a Scout, as I believe they came out a year or so later.
I have checked year codes in the following parts lists:
http://www.partscats.info/skoda/en/?i=cat_vag_models&brand=sk&number=81
My VIN starts with 1Z8, yet that appears on the list to be a 2008 vehicle.
Can anyone help with this confusion?
Thanks, TT
List the 3 digit PR codes in the front of the service handbook or on the sticker on the boot floor and someone should be able to tell you what rear brakes are fitted.
Thanks, Scouter, I'll check that.
I had the same palaver sorting discs, pads, calipers for both my skoda's recently, one being same car as yours. If its any help, main dealer receipt for 4x4 shows
rear pads - 1K0698451G
rear discs - DSK2218
Thank you all for your help, problem now sorted. More serious than I thought, rear nearside wheel bearing failed and bolt heads worn so it became a (expensive!) garage job!
