Calling Expert's!
I've noticed when i'm taking picture's later on viewing on big screen i have a patch of detail,and slightly different colour.
Can you tell from these?
Is my camera broken,or user error,how can i lose it and get more detail instead of blur.noise.
I think this is more to do with depth of field, your aperture must be wide open and the part that looks a different colour is the part that is in focus because of depth of field.
 Also I notice the images are quite noisey which I think is masking the true colour of the paint beneath the water droplets.
 Post up the EXIF data, it will probably show aperture wide open and a high ISO which may be causing the colour difference.
Edited by James I
Make
FUJIFILM
Model
FinePix S2960
Aperture
4.2
Exposure Time
1/85 (0.0117647058824 sec)
Focal Length
12.3 mm
Flash
Off, Did not fire
File Size
1719 kB
File Type
JPEG
MIME Type
image/jpeg
Image Width
3072
Image Height
1728
Encoding Process
Baseline DCT, Huffman coding
Bits Per Sample
8
Color Components
3
X Resolution
72
Y Resolution
72
Software
Digital Camera FinePix S2960 Ver1.01
YCbCr Sub Sampling
YCbCr4:2:2 (2 1)
YCbCr Positioning
Co-sited
Exposure Program
Program AE
Date and Time (Original)
2016:02:12 18:43:03
Max Aperture Value
3.1
Metering Mode
Multi-segment
Light Source
Unknown
Color Space
sRGB
Sensing Method
One-chip color area
Custom Rendered
Normal
Exposure Mode
Auto
White Balance
Auto
Scene Capture Type
Standard
Sharpness
Normal
Subject Distance Range
Unknown
Quality
FINE
Sequence Number
N/A
F Number
4.2
Exposure Compensation
N/A
Focus Mode
Auto
ISO
800
Compression
JPEG (old-style)
Orientation
Horizontal (normal)
Edited by vrsRo55
As James I mentioned above, you have a large aperture (4.5) which is causing a narrow depth of field. Have a look here for more info. :thumbup:
Its a point and shoot camera can this be adjusted? i think i have a custom/manual mode.its an old camera.
Looks like it can be adjusted. The manual is available here.
Thanks,just having a play now at the dining table with a socket i found on the road,should be interesting.
You will find as the aperture number gets bigger the aperture gets smaller, in turn your shutter speed will get slower because less light can get in, to overcome this your ISO will have to increase which could introduce more noise.
 A bit of flash may help, turn the power down if you can and use as FILL flash.
