Swing radio replacement with Bolero
Hi,
I have Skoda Octavia Combi, Ambiente, year 2009, 1.9.
I have Swing radio, is it possible to replace it with Boler- touchscreen radio? Are there any difficulties? Can I do it on my own, or any computer work need to be done?
Does anyone have any instructions to do that?
Thank you very much
When I first got my octi it had a bolero unit in it, the main problem I had was signal... as I believe the bolero uses two aerials to run correctly (I'll probably be corrected on that) but I took it out as I found no difference to the swing unit, which still plays MP3 discs, and has the multichanger in the boot, I retro fitted my multichanger cost me about £30 in all, oh the only other thing that did not work correctly with the bolero was the heater display ie temp up and down and the reversing sensor display... other than that no real difference I personally would not go to a Bolero again, there was no real benefit to be had other than the sd card interface !  Last thing I find that despite changing my aerial twice now I still suffer with poor reception on my swing unit.
Best of luck whatever you decide....
