A long shot regarding HID coding and sidelight issue afterwards
Hi all been a while since i posted on here as been very busy getting my octy just the way i want it, now for my issue, about 9 months or so ago i fitted the london color hid kit which i was very happy with, coded them in, while i had the longcode up i must of messed about with some tick boxes as ever since ive had no sidelights tail lights work as they should and the front side lights flicker when i switch headlights on but never fully come on,
So,
Has anyone got a late prefl octy ambiente that would share their long code with me so i can either revert mine back to factory and then only code hids in or does anyone know where ive likely gone wrong, i can if needed post up a photo of my long code for reference
Dan
Probably best to post a full autoscan, it'll give you the best chance of restoring your original coding. Mostly as it'll show what else is installed.
Also, if you did an autoscan prior to the changes, it should be saved automatically by VCDS.
Ive just found a scan from when i first bought the car so im going to revert the long code back to this to see if it restores the sidelight functionality, never thought of that before thanks (tbh i forgot I scanned it beforehand)
Dan
