how to test my car alarm
hi i have just purchased a octiva 2011 and im sure it has an alarm fitted i just want to test it so i know how it sounds can anyone help please?
lock the car while you are inside, wait about 30 seconds to a minute and then move about and the interior sensors should set it off
With VCDS you can do output tests.  :)
i take it if i set it off by sitting inside i just use the key fob to turn it off?
Yes like you would normally.
This is a good idea, do you know if you can see the input in the measuring blocks for the interior sensors to check those as well?
Edited by SuperbTWM
Lock the car with the remote
Unlock the car using the keyblade in the door, open the door and wait. Don't turn the ignition on.
Alarm should go off after 20 seconds
thank you everone
Lock Car, stand back and
Open the window, lock the car, wait 30 seconds, then stick your head inside. While you're on doing this, test the "one button press to lock" versus the "two button press to lock" and see what the difference is, so that you know how to properly deadlock the car.
You should unlock the car with the key manually, start it and then the alarm should go on (like stated above).
Sitting in the car might not have any effect because alarms are different. Some of them got sensors inside the car, some not.
Surely all the Octavia's have though
Not necessarily. If it's fitted on factory then might be but if it's done in some garage then they might be very different.
When I had my alarm done (hadn't been installed on factory) then I had different choices. I chose sysem with sensors inside the car but I could avoid them.
