2007 superb elegance
rear parking sensors stopped working -could it be fuses-have accessed fuses but layout very different from my manual any advice appreciated thanks
If you get a single long beep the first time you put it in reverse then it is usually one or more of the sensors, a scan with VCDS indicates which.
Also might be worth checking that the switch that detects reverse gear is engaged is working - does your reverse light work?
thanks jimbof sorry about delay-had long beep unable to fix myself but skoda collected and returned car sensors gone needed replacing ok now
