ABS MODULE/PUMP
looking for help.where abouts is the abs pump located on my fabia vrs mk1???
On the N/S lower bulkhead, it has a load of brake pipes attached to it!
  • Sponsor
Below the engine ECU at the rear of the engine bay on the right as you look from the front.
Have you got a fault code related to it? If so it may well be worth your while to look at the pinned topic called "Extremely useful Fabia thread" or similar, then following the link within about ABS fault and fuse.
Great thanks for the info much appreciated
