Rapid V71 motor problem
Hi everyone!
I have a Rapid 1.6 TDi 2012y and...
... problem with flap motor V71. VCDS showed me the 01274 error with 000 suberror.
With motor is this? Where it is located? I deassemble glovebox, but only motor I can see is on right side of blower.
Any advices?
Thanks in advance!
It's behind the blower. Below is from the service manual:
Remove storage compartment on passenger side
– Carefully release cable from the clips -4-.
– Unplug connector -2- from the control motor.
– Unscrew screws -3- and -5-.
– Pull holder -1- with control motor as far forward as possible,
until the lever no longer engages in the control for control motor.
– Push outside catch at the top of the holder -1- downwards
-arrows- and remove holder with control motor.
– Remove air flow flap control motor from the holder.
While doing so, press the catch pegs -arrows- outwards and
at the same time remove the dynamic pressure flap control
motor from the catches -1-.
Installation is carried out in the reverse order. Pay attention to the
following:
Note
♦ The spare part dynamic pressure flap control motor - V71- is
set to the end position “re-circulating air mode”.
♦ If necessary connect the control motor to the wiring loom and
switch to position “re-circulating air operation”.
– Press the dynamic pressure flap control motor into the holder.
– The following steps must occur simultaneously:
– Guide the holder with control motor in such a way that the lever
-2- grips into the control for the control motor -1-.
– Press the control motor fully into the housing and screw on.
– Insert plug connection, switch on ignition and check operation
of the control motor by pressing the re-circulating air button.
Note
♦ It must be possible to smoothly adjust the fresh air flap and recirculating
air flap up to the stop.
♦ If there are functional problems abort test immediately and repeat
installation.
♦ If the control motor was replaced, perform a basic setting
  • 11 months later...
Anybody got a picture of the potentiometers associated with these motors please?
And how are they connected? Are they replaceable separetely?
  • 3 months later...
If there like the Fabia flap motors its usually the motor that starts acting up !
Here is what the inside of the flap motors on a MK1 Fabia look like - V68 so no not a normal pot !
Edited by sparky2
Yeh I did look into finding a motor but the ones I found all had different cogs on the shaft !  I did take some pics of the insides of the motor but our website says I can only upload 10mb
  • Sponsor
I wouldn't mind a look at those pics, can I PM you an email address?
yeh no probs
sorry for the wait just found some and it looks like its a lock motor from one of the doors on a Fabia, will forward them now
Your probably right wino its the carbon track on the flap motors and the motors themselves on the door locks, I also have a pic of V154 out of the fabia which has a slightly different pot if thats of any use ?
  • Sponsor
34 minutes ago, sparky2 said:
Your probably right
I wouldn't be too sure about that. I cut into one of the pots a while back and was surprised that it didn't look as cheap and nasty as I expected. It's a moving part, so subject to wear, but I think the wiper had at least two contact points, if not more, so quite robust, except possibly vulnerable to debris accumulation.
The motor is something I hadn't really thought much about. Much faster moving than the pot. Will check out all the pics you've sent tomorrow. :thumbup:
Edited by Wino
Yeh must admit I checked out the ones in the flap motors and like you say there well made, I applied some switch cleaner to the tracks but it was only short lived, I will have to google the pot part numbers now.
