Disable Alarm
When i locked my car with remote whilst having rest inside car the alarm went off, how can i stop this happening again
Press the little button at the bottom of the B pillar before you get out. It disables the internal sensors.
Sent from my D5803 using Tapatalk
Right, but if you want to stay in the car locked (hopefully with the key on you), you have to open the door, press the button on the B pillar, shut the door, then lock the car and... enjoy your rest  :zzz: .
This procedure applies also when leaving the car locked with the windows slightly opened, like on very sunny days.
If you want to sit in the car with the doors locked just press the button inside to lock the doors as this doesn't enable the alarm. Only the key enables the alarm but the lock/unlock button inside the car doesn't.
Yup, would have thought this was the obvious answer :D  It's designed for such uses, as well as anti hijack.
Anyone know where this button is on an Octavia 3 combi?
It was on the B pillar on my Passat, can't find it on Octy
