Larger tires from OEM
Hi!
Does someone have larger tires than the original? Can it be a problem?
Tires can be too wide and that extends out of the fender or that bother some parts?
I currently have 225/50/17. I'd like to put 235/45/17 or 245/45/17.
I have OEM alu ET 45. Car is Yeti 2.0, 110hp 4x4.
Here you see that someone put 245/45/17:
http://www.team-bhp.com/forum/diy-do-yourself/152362-my-skoda-yeti-diys-oe-upgrades-custom-mods-update-park-assist-video-page-8-a-11.html
At Tyre Calculator is the difference between 225/50/17 and 235/45/17 small. So diameter is fine. The tires in these two dimensions almost the same.
http://www.willtheyfit.com/index.php?width=225&aspect=50&diameter=17&wheelwidth=6.5&offset=45&width2=235&aspect2=45&diameter2=17&wheelwidth2=6.5&offset2=45&Submit=Calculate#content
According to the law in my country, I can enter dimensions differently than recommended by Skoda.
Price for 4 tires in dimension 235 is 100 EUR cheaper then 225 (OEM).
Thank you very much,
Marko
Edited by Zmay
The 235 / 45 would be the better of the two larger options
You also need to take into consideration the width of the rim I'm sure a 245 tyre needs to be mounted on a 8&1/2" wide rim
Thank you.
I have Dolomite 7.0J x 17”.
So 235 / 45 can be install without a problem?
  • 4 weeks later...
Anyone? :)
Use this website to understand the differences of different sized tyres...
http://www.willtheyfit.com/#isPage=1
It will tell you how much closer to the suspension strut the tyre will be, you can then measure it yourself and check to see if it will interfere with the suspension, wheelarch liner or inner wing.
The profile of the Yeti (and Octavia Scout) tyres are tailored for a higher profile to contribute to the ride height and off road capabilities. What is behind the desire the fit lower profile and wider tyres?
Here is a Scout (same size wheels and tyres as the Yeti Dolomites) with 18" lower profile and wider tyres / wheels from the VW Passat Alltrack...
Thank you. I checked before on that site.
Here is result.
1st is 225, 2nd is 235.
Diameter
656.8mm
643.3mm
Circumference
2063.4mm
2021mm
Poke
37.6mm
37.6mm
Inset
127.6mm
127.6mm
Speedo error
0%
2.1%
Reading at 30mph
30mph
30.63mph
Reading at 60mph
60mph
61.26mph
Ride height gain
0mm
-6.75mm
Arch gap loss
0mm
-6.75mm
Well, for first is a price. Tyres in 235/45 are 100EUR chepear then 225/50, for 4 tyres.
Second, wider tyeres will look nicer, and Yeti will be lower for few mm :)
So why not combine two good things. I thing it is not a big difference.
I have 215/60/17 for winter. I got it OEM with car.
Winter is time when I have little bit off road and when I need bigger ground clearence, which is 200 mm (20 mm more by 215/60/17).
I have no problems with handling, and mechanic said that everything is O.K. with suspension etc.
Edited by Zmay
