door unlock
is it possible to unlock all doors with one press on remote button?
also enable needle swipe during start
activate drl
enable alarm sound
pls give your feedback
skoda oct 2 1.8 tsi ambient
Doors can probably be done.
Needle sweep depends on software version of the clusters.
If DRL are fitted and disabled, normally yes.
Assuming you have an alarm, yes.
You might be better off posting in the VCDS section with an autoscan http://www.briskoda.net/forums/forum/23-diagnostics-vcds/ as these are questions and not a technical guide.
You should also read through this: http://www.briskoda.net/forums/topic/229766-vcds-adaptations-how-do-i/
