Urgent battery issue
Ok so go to pick daughter up from school car starts fine. Go back to car and battery dead. Get it jump started and get home and it's showing 12.2v at battery and 14.4v running so all seems well there but VCDS scan is awash with intermittent faults and controllers not active such as infotainment.
The battery has been on the car as long as I've had it so no idea if it's been changed or when. So, new battery time. Go onto euro car parts to price up a Bosch S4 075 but EcP telling me it should be an 012 yet the car has a 075 fitted and the woman on chat is telling me that is wrong? What battery should I have?
Also while under the hood checked fuses in ebox and noticed that the larger Grey relay in R4 was quite hot. Anyone know what that's for? Can't find any info in manual or net regarding relays.
Octavia will take
Ebay 096/100 044 calcium 5 year £45 delivered. Or less. Advanced battery services aka ABS.
I have one in my TDI Octy as do some other members here.
Isn't an 096 a bit overkill for a petrol engine?
Yeah perhaps it is as this was the largest for the TDI. However this seller posts next day for your size too I'm sure Perhaps upgrade it a little yourself.
ok so ive replaced the battery and now i have a whole host of fault codes that wont erase and i have the airbag warning light on and no stereo.  Have checked all fuses and all are ok.
VCDS Version: Release
Data version:
Wednesday,22,June,2016,10:24:45:62939
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBBB21Z0580*****
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Sporadic communication error 1000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 03C-906-056-BAG.lbl
   Part No SW: 03C 906 056 L    HW: Hardware No
   Component: MED9.5.10       G00 6101
   Revision: 00000000    Serial number: SKZ7Z0D2542710
   Coding: 0000071
   Shop #: WSC 25031 210 95395
   VCID: 2C57E23B8FFEEC7E18B-8079
No fault code found.
Readiness: 1110 0101
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 N
   Component: ASR FRONT MK70      0103
   Coding: 0017025
   Shop #: WSC 73430 790 00000
   VCID: 3D71DF7F648475F6BF5-8068
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1Z0 907 044 D
   Component: ClimatronicPQ35 083 0303
   Shop #: WSC 00000 000 00000
   VCID: 377DCD5746B85FA6659-8062
4 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
            004 - No Signal/Communication - Intermittent
01317 - Control Module in Instrument Cluster (J285)
00576 - Terminal 15
            002 - Lower Limit Exceeded - Intermittent
00229 - Refrigerant Pressure
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 T    HW: 1K0 937 049 T*
   Component: Bordnetz-SG 1.0 H29 0704
   Revision: 00029000    Serial number: 00000001316693
   Coding: C18E0F220004140032110D000000000000
   Shop #: WSC 73430 790 12345
   VCID: 408FA68B1376181ED43-8015
   Subsystem 1 - Part No: 1Z2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00065525
   Shop #: WSC 73430
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00217125
   Shop #: WSC 73430
5 Faults Found:
01321 - Control Module for Airbags (J234)
            008 - Implausible Signal - Intermittent
01314 - Engine Control Module
00926 - Terminal 30
            011 - Open Circuit - Intermittent
00834 - Signal for Activation of Heated Rear Window
            009 - Open or Short to Ground - Intermittent
00924 - Relay for Headlamp Cleaning System (J39)
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 K    HW: 1K0 909 605 K
   Component: 04 AIRBAG VW8   024 0700
   Revision: 07024000    Serial number: 00378D050WL3
   Coding: 0012340
   VCID: 3467FA5B57CEB4BE40B-8061
   Subsystem 1 - Serial number: 6332MSME24153A03
   Subsystem 2 - Serial number: 6342MSME7F6E5E03
1 Fault Found:
            004 - No Signal/Communication - Intermittent - MIL ON
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 012 0030
   Coding: 0000042
   VCID: 306FF64BA3D6889E243-8065
Any ideas?
ok managed to get some to clear but still have no radio and have the following scan
Data version:
Wednesday,22,June,2016,12:06:51:62939
VIN: TMBBB21Z0580*****   Mileage: 188460km/117103miles
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
   Coding: 0000071
   Coding: 0017025
1 Fault Found:
   Coding: 00065525
   Shop #: WSC 73430
   Coding: 00217125
   Shop #: WSC 73430
1 Fault Found:
   Coding: 0012340
   Coding: 0000042
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1Z0 920 910 B
   Component: KOMBIINSTRUMENT VD1 3558
   Coding: 0005401
   Shop #: WSC 26018 576 105914
   VCID: 326BFC43ADDABA8E527-8067
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 27001046250137
   Coding: 3D3F0340071303
   VCID: 29591B2F800CF956E3D-807C
2 Faults Found:
01305 - Databus for Infotainment
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 1
                    Fault Frequency: 10
                    Reset counter: 15
                    Mileage: 188467 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:14:23
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 9
                    Reset counter: 15
                    Mileage: 188467 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:14:27
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO                3558
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1T0 959 701
   Component: Tuersteuergeraet 09 0166
   Coding: 0000118
   VCID: F4E7BA5B974E74BE00B-80A1
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 G
   Component: EPS_ZFLS Kl.1       1301
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 BL
   Component: 01 KSG              0301
   Coding: 00F802007F2D0404485F865004
   VCID: 7BF511673A10BBC6C11-802E
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.005 4801
   Coding: 00000000
   Shop #: WSC 00000
   Subsystem 6 - Part No: 1K0 951 605 A
   Component: LIN BACKUP HORN H01 1201
   Subsystem 7 - Component:       NGS n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1T0 959 702
   Coding: 0000118
   VCID: F5E1875F9C346DB6375-80A0
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 B
   Component: Tuersteuergeraet 06 0215
   Coding: 0000048
   VCID: 2F6DF537BEE897663D9-807A
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 B
   Coding: 0000048
End   ---------------------------------------------------------------------
Not worried about the low refrigerant one as i know the system needs regassing but have no radio :no: .  Checked all the fuses including the one in the back of the HU and they aare all ok, even swapped the 15A radio one with rear wiper one and fuse definately ok.  getting power to the fuse in the ebox, just appears as somethings not communicating?
I HATE CANBUS CARS :peek:
Is it the standard headunit or aftermarket?
Did you check that you were getting 12v at the headunit connector on both the power pins?
It is a standard unit yes. Just basic stream. havent checked power at HU will do that now and report back.
Done all fixed and no fault codes present except aircon one which needs regassing and one for headlamp washer relay. Anyone know where that's located?
No idea what caused radio fault. Unplugged radio, checked and had power at plugs. Placed circuit tester over both pins of fuse and all ok. Decided to change fuse just to eliminate that. Plugged back in and radio fired up. Removed new fuse and put old one back in and radio still working. Guess just some sort of gremlin in the system.
The headlight washers are probably a blown or even missing fuse looking at other reports of the same error code.
In another thread, it was suggested it's fuse 36 in the panel at the drivers side of the dash. Remember that numbering is mirrored so it might not be the first fuse you think it is...
Yeah already checked every fuse in that fuse board so I know they are all ok. Wait for it to stop raining and I'll replace it anyway as I have loads laying around.
The Varta E44 type 096 is exactly the same battery as the Bosch S5 only cheaper. Can highly reccomend. Tanya were the cheapest when I last looked.
Mark
