Aircon problem on Fabia Comfort 1.4 2001 plate
Put my Fabia 1.4 Comfort (19k miles only) into local garage today for AIRCON charge
Garage advised that a fault code on the recharge machine showed apparently an evaporator problem
The garage is seeking advice as to how to fix from elsewhere, but they are uncertain if the "works" is mounted under the dashboard on the passenger side  - or the drivers side
If the latter it may mean taking off the steering wheel and part of the dash board to get "at it"
Any advice as to where and how would be appreciated
Lodestone
Maybe this will help you.
  • Sponsor
Right in the middle isn't it? Where the A/C pipework goes through from the engine bay, evaporator is just the other side of the firewall.
Get vcds on it, might just be evaporator temperature sensor?
I'm suspecting the evap temp sensor. There is a guide on here somewhere iirc.
This one ?
That's the one.
More details - the fault code is 00818 sensor for evap outlet temp G263
Your advice as to what the fault is, where is it - and how does one get to it to replace etc
Lodestone
Lodestone
The link is in post #5 already.
Many thanks to all those Fabia owners who have responded with excellent advice  on this aircon subject
As my local garage in Southeast Essex are not skilled in aircon repairs , I shall be considering utilising an auto aircon  company and have located some who say they specialise in this field
Any recommendations please re a reliable and competent aircon repairer for the Southend on Sea area ?
Lodestone
  • Sponsor
It's not really an aircon repair at this point, it's just removing and replacing a sensor from the depths of the dash. No specialist knowledge of aircon is relevant.
Just to explain: the sensor doesn't go into the refrigerant circuit, it just sits **close to** the evaporator.
Edited by Wino
