Help with DOS command
I have a DOS command that I can run from the root directory of a drive or network share and it will list the folder name (not file name) that contains any MP4 files, however, it lists to screen and I am trying to get it to list to a text file but the usual >output.txt won't work - any suggestions?
Here is the command I am using:
for /r %a in (.) do @if exist "%~fa\*.mp4" echo %~fa
Cancel that - it needed to be >>output.txt
even better try having a look at Powershell it is DOS on steriods
John
I'd be thinking do
dir *.mp4 /s > output.csv
open the file in excel and just filter the data to show any rows starting "c:\..."
I'd recommend ZTREE to look inside Directories ( old name for FOLDERS).You can also search by file type using the known file type extension ( e.g for applications in a directory, type in ,in the file line *.exe). Alternatively in DOS, you can access a directory ( DIR/W/P, gives a list that stops when page is full, CD ,"DIR" will access a directory of name "dir" and cd// will return to root). Advantage of ZTREE is that you have no file length name restriction( unlike pure DOS /XTREE), and it's a menu driven system. Again there is also XTREE,( older version, which has file name length restrictions), but will work a lot better in old versions of DOS, where ZTREE might not. I've never tried printing from either, so no help there .
Move to linux? :p
Colour me impressed if you know how to do that from the shell off the top of your head!
Off the top of my head, the following should do it, where $DIR is replaced by the top level directory:
find $DIR -type f -iname '*.mp4' -print > foobar.txt
Wonder how many errors I have in there.
Edited by cheezemonkhai
Sounds legit enough to impress me.
Problem with most of these suggestions is it will give me a list of files - I just want the folder names that those files are in. There could be thousands of files but only dozens of directories
back to powershell
$type = "*.mp4"   this is the type of file you are looking for
dir c:\$type -Recurse | Select Directory -Unique | sort Directory | Export-Csv c:\data\info.txt
this will check for all mp4 files on the C drive and put the directories they are in into a file called info.txt in a directory called data on C drive
John
Martin - find one file you know of in a directory- it will have a file  extension-as I mentioned applications have file extensions of .exe. Batch files are .bat . Then on ZTREE , use the F tag to ask Ztrtee to look for look for files of the type you  want. OR , YOU CAN do it in DOS- but it's more demanding- as you  have to search through each directory using the tag dir*."file" .I'd use Z TREE - IT wil search dozens of directories.
quote name="jjc" post="4661295" timestamp="1467729599"]
back to powershell
John
Proof be it windows or Linux, that a proper shell is always the answer :)
back to powershell
John
Thats the best soloution i've seen in this thread so far.
Similarly in DOS ,TYPE IN DIR *.MP4 (I THINK FROM MEMORY)
Simpler in ZTREE- open ztree ,which will show folders in root.
using the instructions, you will find that one use of the F key will select files and ask for filename -- enter MP4, press enter and a list of all files *.mp4 will be returned.  will be returned.
using other keys you can select drive, although i don't know if you can do it in true dos.
HOWEVER- unless PC is opened in DOS, you will need to download the correct version ( 32/64 bit), which will run under Windows in DOS mode.
I do assume that drive(s) you wish to access are formatted in dos ( if not- forget line 1), but however, there is a bootable CD available on line which wil boot up a PC from NTFS and let you look at root etc.
