Non maxidot digital mph display
Ok so to confirm from a post on here. Mph can be displayed by changing my dash unit to Australia with carista. U then turn your trip reset button till the kph flashes and press it to change to center display. This is in mph. But i think it sets the units to US gallons as my avg consumption went to 40 from 45 as soon as i changed it and goes back to normal a soon as you change back to uk. So question is now once in Australia setting can US gallons be changed to uk gallons via vcds?
Run for 2 days now in Australia setting and definitely showing lower mpg. Any ideas anyone ?
On my pre facelift with a maxidot screen i have the option to change between us and UK mpg.
Is there something similar on the facelift?
Not that i have seen.
There is for the FL Maxodot, not sure if it's possible to change on a non-maxidot.
I dont have maxidot. Thats the problem.
Sure, I was just confirming that it's definitely possible on a FL maxidot so it might be on a FL non-maxidot :)
Not unless theres a way with vcds. Im sure you can trim the mpg display with vcds but never done it and i would hate to mess it up completely lol. So not sure if that would work or not.
Yes, you can adjust the MPG via VCDS, it's done as a percentage though an adaption channel. I believe the min/max is 85% and 115% so not enough to make up for the difference between US and UK MPG.
Best bet it to plug VCDS in and inspect the adaption channels to see what there is :)
