Suspension Problems already see pic's
My whole front end suspension was revamped few months ago...
I have got an annoying mouse squeak over 30mph and under a slight clunk.
I was rather hoping it would be new suspension bedding in.
Then i thought track rod end's as i belted the NSF quite hard.
Anyway had a spare 30min's so removed the wheel to find this.
I cannot for the life of me understand it.
Any suggestion's?
804EE74D-AB60-4339-B3DA-520A3A302536_zps
9D9EBA40-F1E8-4249-B83C-FCB15837DC8B_zps
I'd put some paint on it and see if it comes back soon--assume the springs only fit one way  (upside down?)
When under load (IE the weight of the car) the progression of the spring is not enough - are they lowering springs.
Paul
Yes correct one way fit i checked all that before fitting them,shock's are either side also.
I put some pipe with some cable tie's around the area,it is still squeaking.
Yes they are APEX 20mm spring's.
Could the shock be faulty?
Need some of these i think....
I'd love to see how the spring sits at the top
and the overall position of the spring when under load - do you have another jack (trolley jack) the you could position under the lower radius arm and jack up suspension up until its under complete compression.
Brad lol top 3 coils almost touch.whilst i was parked on a steep hill earlier i looked.
Other side seem's ok,bit close mind.
Not sure what's faulty,ECP have ordered a new kit for me to swap.
Is there any point in upgrading shock's? Bilstein?
Hopefully that should sort it.But can't see them lasting long with the B-road's i commute on.
Well i'm gobsmacked.
I went apex as i heard stories of H&R coils touching.
Just took these whilst car on ground.
This is the driver's side....
7CCF846E-72CB-4D3D-837F-6D4A194EE764_zps
90C356FB-3EA5-4974-98AF-7301B598233E_zps
Passenger side
See where i put some petrol pipe
25F6A396-27B0-40DB-95E6-3478201A6B76_zps
Spring clatter is common on lowering springs, especially cheap ones like Apex
Only NSF is the issue,gearbox extra weight maybe.
I am really chuffed with them TBH,There is no way i'd go back standard.Crashy and hard.
Roll has been almost ruled out.
Don't even see the need for better ARB.
I have a new spring from ECP i will post a pic soon.
I am going to order some piping.
H&R do the exact same thing and they definatly arnt cheap.
Cheaper then Eibach
New spring
590BFE05-2987-4625-983D-F22B8B05C718_zps
5D133EE9-42F9-4838-BAB6-BD177F581159_zps
Clatter or touch the shock?
I'm getting a clunk under 30 over a squeak.
I knew H&R did squeak which was why i avoided them.
I'm going to fit the new spring,and see what happen's.
I don't really want to hack at my shock's.
I may buy some Bilstein's.
Don't want coilover's as i travel country road's a lot.
Does anyone think i'd get away with new shock's?
judging from the first pic'    I would be inclined to "dress" down the spring carrier/ broken spring catcher
What do you mean exactly...
Ross
before you go any further and do not do the above recommendation - I would contact Apex and advise them as to whats happened and send them your pictures and see what they say.
paul
^^^^ I thought about this but cannot find them online.
I fitted my disc's and pad's today.And the driver's side is identical to the NSF.
I have double checked the front shock's they are correct.
Only thing i can think of is,because it's the very late cr170 and slightly heavier than the PD170.
Since i have jacked it up the squeak has gone also the clunk,but when settled again it will return.
Thank you for above info!
Here you go  :x
95B18E32-BD0B-47EA-9298-855C2547A69F_zps
5B2283D5-2E7F-464D-B89F-DB7A5874EBA2_zps
A3C832AD-82E9-4A58-B045-A8E11FAF6F03_zps
331B3180-0940-479E-9251-BBB421946B47_zps
546DA656-4302-44C1-8502-FA3DA227446D_zps
The H&R cup kit springs on our CR FL also touch. Never noticed any noise but you can see the marks on the springs.
