Need help on changing car battery - 2011 superb
Howdy
About time to change my battery, i´ve searched for howtos/youtube without luck, what tools are needed and what nuts/bults to i need to remove in order to get out the battery?
There seems to be a bult on the longside of the battery closer to the center of the car, is that one of them?
regards /b
IIRC you need 10 and 13mm sockets/spanners. First remove the negative cable from the battery, then the positive. After removing the cables remove the fabric battery cover (that's what I had. There might be plastic versions though IDK) and then loosen the bolt (be careful not to drop the bolt/bracket) on the bracket that holds the battery in place. I used a socket with an extension. Replace the battery and do the steps in reverse order.
