Where to get door seals from?
I've had a quick scout on eBay (preferred place for car parts), however they don't have any new rear door seals. Also done a quick google search but nothing really coming up. Any ideas?
Secondly, are they easy to fit?
I got 4 new door seals for my Roomster from Coventry Skoda [email protected]
Email Craig and include you VIN number
You simply pull the old off and press the new on. I found the front a bit tight to get behind the dash but with a bit of pushing in is possible. I bet they factory fit before the dash goes in. I found that the join in the seal is in line with the lower door hinge, not sure if that matters but installed the same.
Also I had to push the seal onto itself as I pushed it on. Otherwise it ends up too long around the door.
But not hard to fit I did all 4 in ½ an hour.
My Roomster ones were £25 each so £100 + delivery in total.
