Heater fan not working
My heater fan has just stopped working , will it be a relay or fuse ? And we're is the relays on a 54 plate ? Thanks
Have a search for heater resistor :)
  • Sponsor
Does it work on speed 4?
No it won't work at all ? I want to check the easy things before pulling car apart to replace the fan it's self if that makes sense
  • Sponsor
There's a post in the Fabia Tech Guides section with all the fuses listed. Find the relevant one and check it.
Thanks wino
F68, ON PAGE 12.21 OF HAYNES. Hint- it's 25A on bottom row .
Thanks vwd , will have a look ,
I have checked the fuse and relay and all seem fine but fan still not working, what should I check next ? Thanks
  • Sponsor
Check that with switch in position 4 there is 12V at the last two-way connection to the fan under the glovebox, if that's there, the problem must be the fan itself.
Edited by Wino
Thank you ! Will check now
I have power at the fan , I wired a bulb to the fan plug and it gets brighter when I turn fan up , next question will the fan out of my sdi fit ? Thanks for your help
Forget that it's working! Just pulled aload of leves out of the fan it's self and now it's going!
Thanks for your help !
Edited by Vfr400boy
  • Sponsor
Hehe, I didn't think of mechanical obstruction.
May be worth checking your pollen filter too.
Bets that he doesn't have one any more?
  • Sponsor
It's downstream of the fan on Fabias, so no, not betting that.
  • 4 weeks later...
She's packed in again! Will have a look in the morning and see it it's more leaves some thing more serious,
