Is my alarm siren faulty?
Evening all
Just thought I'd check my alarm out of curiosity to see if it sirens but I'm having no joy.
Sat in the car and locking it via the fob doesn't seem to set the sensors off and I can see on the internal pillar that the alarm sounder tab isn't lit.
That sound right?
Do I have a dead siren or am I missing something here?
It has worked in the past by the way but have had some problems with a garage when they messed up my car after a service. Could they have done something?
lock the car with the remote, then open the drivers door using the key in the lock.
Open the door and wait about 20 seconds the alarm should go off
The alarm system does take a short while to arm itself, do as above to check the alarm works on the door switches or lock the car with the window down, wait a few minutes and wave your hand inside to check the interior sensors work.
Edited by SuperbTWM
Evening all
That sound right?
How are you locking the car? With a single click of the remote or a double click?
I will have another check of it tomorrow and post back the findings.
Incidentally, I click the fob only once when locking the car as I believe doing it twice disarms it, if that is correct.
Yep, just checking. Single click locks and arms the alarm, and deadlocks it. Double click disarms the interior sensors and deactivates the deadlocks.
Hi all. Interested in this. Mine works, though the alarm siren has stopped working after checking fuse 35- 20 Amp is OK. Only lights flash so I'm getting new siren.
But what difference does clicking the fob once or twice to lock make?  First time I'v heard of this. ( Also, is a 20amp fuse correct for alarm? Thanks.)
OK I was a bit slow there. Thanks for the answer ^^
Ok, so checked the alarm today. Locked car via fob with drivers window opened and waited about 30 secs. Waved arms inside and hey presto siren went off.
However, locking car remotely and then unlocking the door via drivers door lock (as Eddie-NL) suggests does nothing.
Unlocking it via the door though makes the alarm system chirp and seems to disarm the system. Unless I'm being thick the only way to test it is either sit in car or do the 'wave through window' trick.
Wasn't doing anything yesterday so will deffo keep my eye and ears on this. Got really paranoid as I had a diesel leak and thought it may have scuppered the alarm. I'm a bit relieved now to say the least.
Do your interior lights and door open warning light come on when you open your driver's door?
If it chrips it appears that unlocking with the key is disabling the alarm so I wouldn't worry, it all sounds ok to me
Your alarm horn is probably dead, get it scanned with vcds to see if there is a fault with it
I had this on my mk5 golf, it would chirp when locked but when unlocked with the key in the door just the indicators would flash
The siren has it's own battery I believe which I'm sure it's mentioned somewhere should be changed every 6 years.  Mine never has as far as I know and still works.  Not sure if the battery is part of the siren and has to be ordered as a complete unit or if just the battery can be changed.
The battery is part of the siren and is one part.
It is possible to replace the batteries, but you have to physically cut open the siren and solder in new batteries.
Not worth the hassle when a new siren with new batteries can be had for £25.
flea bay?   the stealers were approx£160 last time I looked
Don't bother with second hand. The battery will die soon.
Get a new one on Aliexpress direct from China for £25.
Agree with soft scoop,I got one from Ali express
thanks to a post soft scoop made sod paying dealer and second hand is not worth it
Are you saying then that by me unlocking the car manually after locking it via the fob, the alarm should definitely sound? Sorry, just a tad confused when you say the alarm horn is probably dead. It sounds if I lock the car and sit in it so I'm assuming it can't be the alarm horn or am I missing something here?
I found out when taking the window regulator out of the door that my car had an alarm.... Didn't realise the door wouldn't lock without it so the car thought the car had been opened but not unlocked
I found by locking car using remote control lock button pressed once, with my labrador inside car, with her movement around inside car soon sets off my alarm of..LOL
But to hit remote lock button twice will stop the alarm being triggered off..by the dog inside..
Edited by giandougl
If you unlock with the key you have around 15 seconds to turn on the ignition to prevent the alarm going off.  At least that's what my manual says, I've not tried it out.
Is this siren from aliexpress an exact replacement? Do you have a link for it please?
Is the AliExpress one a direct fit? Only asking as it comes with wiring.
