Help - Yet another Octavia with door locking issues.
Having read a number of threads on this I'm totally confused and in need of help.
Car is an 02 TDI elegance combi.
Any clues here :
(i) Opening driver  door usually gets internal light to come on but door open light on dash is off and puddle light is off ( occassionally the internal light does not come on - this might be due to the switch on the light itself having an intermittent )
(ii) Unlock with FOB and get into drivers seat & shut door - usually all doors will lock after 30 seconds. Sometimes the driver door remains unlocked and the others lock
(iii) The driver side rear passenger door took to deadlocking itself and not unlocking. I'm not convinced that this is due to that lock being faulty ( perhaps its a consequence of this other  issue ? ). So, for the time being,  I've pulled the connector off that door lock.
I cleared codes and ran an autoscan. Result as follows :
Monday,12,September,2016,11:55:12:29926
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
www.Ross-Tech.com
VIN: TMBGP21U622641748   License Plate: AUTOSCAN 20160912A
Mileage: 188380km-117053mi   Repair Order:
Chassis Type: 1U (1U - Skoda Octavia (1997 > 2011))
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 56 76
VIN: TMBGP21U622641748   Mileage: 188380km-117053miles
Address 01: Engine        Labels: Redir Fail!
   Part No: 038 906 012 CL
   Component: 1,9l R4 EDC 0500SG  3359
   Coding: 00002
   Shop #: WSC 31480
   VCID: 5CBC71F6CC5F61DE61-4A6A
   TMBGP21U622641748     SKZ7Z0B1390609
No fault code found.
Readiness: N/A
Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
   Part No: 1C0 907 379 K
   Component: ASR FRONT MK60      0103
   Coding: 0021505
   Shop #: WSC 31480 000 00000
   VCID: 3260FF4EAE5B87AE9B-50AC
Address 08: Auto HVAC        Labels: 1Ux-907-044.lbl
   Part No: 1U1 907 044 A
   Component: CLIMATRONIC     C 2.0.0
   Coding: 11000
   Shop #: WSC 31480
   VCID: 3064F546F057B5BEED-50C8
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605
   Component: 0L AIRBAG VW51 0B   0004
   Coding: 12364
   Shop #: WSC 31480
   VCID: 61C24002EB3D4C3632-5072
Address 17: Instruments        Labels: 1U0-920-xxx-17.lbl
   Part No: 1U0 920 911 F
   Component: KOMBI+WEGFAHRSP VDO V07
   Coding: 23412
   Shop #: WSC 31480
   VCID: 3260FF4EFE5B87AE9B-508E
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 31480
   VCID: 70E4354630D7F5BEAD-508E
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799 B
   Component: 4Q Komfortgerát HLO 0003
   Coding: 00259
   Shop #: WSC 31480
   VCID: 3668C35E12339B8EB7-4A6A
   Subsystem 1 - Part No: 1U6959802D
   Component: 4Q Tõrsteuer.FS KLO 0004
   Subsystem 2 - Part No: 1U6959801D
   Component: 4Q Tõrsteuer.BF KLO 0004
   Subsystem 3 - Part No: 1U0959811D
   Component: 4Q Tõrsteuer.HL KLO 0004
   Subsystem 4 - Part No: 1U0959812D
   Component: 4Q Tõrsteuer.HR KLO 0004
Address 56: Radio        Labels: 1J0-035-18x-56.lbl
   Part No: 1U0 035 161 D
   Component:  Radio GRO         0001
   Coding: 00407
   Shop #: WSC 31480
   VCID: 2A50E72ED68BCF6E23-4A6A
End-------------------------(Elapsed Time: 03:59)--------------------------
FWIW all the windows work as they should both from internal controls and drivers door key.
Where sould I start looking and what should I be looking for ?
( In some threads on locking issues I've seen reference to connections 'under the carpet' - where are these located ? )
If it's an intermittent fault, I would have a look at the wiring in between the A pillar and the door where it passes through the convoluted rubber boot. They are prone to stress related damage from the opening and closing of the door. It could also be the micro switches on the door catch itself causing issues (there is a good write up on the forum somewhere), as they control the functions that are missing from your description - interior light, door open indicator, central locking etc.
The switches can be replaced fairly cheaply, although it's quite a faff about to do them from how I understand it, other options include a new mechanism (££££'s) or take a chance on a 2nd hand unit. If/when mine decides to give up, I think I will get a 2nd hand catch and fit new switches to that before fitting it to the car.
Chinese lock mechs on ebay are good for the money. I fitted one to the Ibiza and (while its working, touch wood) it's nicer than a gen one. Less clunky and smoother. Was about 35 quid from a UK seller.
As said i and ii sound like microswitch issues and wiring is worth checking. Check the big multiplugs on window motors too for corroded or missing pins.
All VAG cars of that age lock after 30 seconds, unless you turn on the ignition.
They don't relock if you open and close a door, at least all the ones I've been near do that.
The wiring loom in the door is something ridiculous like an inch short from the factory, meaning over time the cables get damaged and break. Octyal mentioned this already. Just pull the rubber boot back and check the cables.
Yeah the ecu knows when a door has been opened and won't lock again until you drive off and go over 10 (if you have anti hijack on). It's a classic microswitch fault as when it plays up the ecu doesn't know the door has been opened and will lock when it shouldn't. New/good used mech will sort most of your problems, stuff digging out microswitches for a lark.
Thanks all for your help.
So its looking like the microswitch.
I've got hold of a Haynes manual. Are the wiring diagrams in it generally accurate ?
If the wiring checks out I'll probably get a new lock rather than try to fix the microswitch
Preferring Amazon over Ebay would
https://www.amazon.co.uk/Mechanism-Number-3B1837016A-Passat-Shipping/dp/B00DM3YUGC/ref=sr_1_3?ie=UTF8&qid=1473933877&sr=8-3&keywords=right+front+door+lock+skoda
do the job ?
( Indeed has anyone tried one of these ? )
There are a few different listings for the item on Amazon for the life of me I cant see how do they differ ?
I have an ebay chinese lock in my back door, its been perfect and less faff than changing microswitch. Respect to anyone who does that, btw, i just didnt have the time.
If its not the wiring its the lock mech switch. The wiring in the A pillar is easy check any way..
