Electric drivers seat gremlins?
Morning all, my drivers seat adjustment is bugging the life out of me.1, no matter how many times I set the memory,it is different after the Mrs has used it.2 ,I'm positive the seat is not going as low as it used to.i now for a fact it isn't as I had it lower, moved it higher,then it wouldn't let me go higher again. Has anyone come across this before......
Morning all, my drivers seat adjustment is bugging the life out of me.1, no matter how many times I set the memory,it is different after the Mrs has used it.2 ,I'm positive the seat is not going as low as it used to.i now for a fact it isn't as I had it lower, moved it higher,then it wouldn't let me go higher again. Has anyone come across this before......[/quo]Sorry not as low as before again, and apologies for the spelling, still half asleep.
I had water in the memory button causing havoc with mine reclining the seat when car was closed..
Just pop out the 3 memory button switch and disconnect from plug and see if you can use the adjuster again..
I opened the switch up and found a lot of corrosion and dampness inside.... cleaned it off and used electrical contact cleaner and has worked for  about over 2 months now  :nerd:
I know I will eventually have to replace
Also as you say its different after the mrs uses it it might just be simply that she is using the other key which has a different programmed setting
Look here http://www.briskoda.net/forums/topic/315378-phantom-seats/?hl=%2Bmemory+%2Bseats#entry4709627
Edited by DEL80Y
No same key del80y.
