Removing rear bumper reflector
Hi Everyone, i was wondering if anyone know how to remove the reflectors that is sitting on the rear bumper under the rear lamps. Do i need to remove the bumper or can i pop it out from the outside somehow?
Best regards
Jonas
Best regards
Jonas
Not sure about the Mk3 but they were just a push fit on the Mk2.
The reflector is a legal requirement.
They can be popped out from the outside, if done very carefully with small prising tool and avoidance of paint damage
Thank you for your replies, to Clarify im tolkning about a standard octy, not the RS one as M12MKD seems to have Linked to?
I will try carefully to pop the out with a plastic troligtvis this weekend and be back with The results :)
Why do you want to remove them?
For instance i disliked the reflector, and covered it with some black reflective tape. I'm more than happy with the result, except when i get too close.
Don't know about Sweden, but in the UK, like auditek says, it's a legal requirement.
I want to remove them so i can cover them with matte black vinyl, but maybe i just do it when they are still on the Car.
Its probably illegal Here to, but illa take my chances ;-)
More fool you, then. It's a legal requirement for a reason.
If keep the car until it is due an MOT you might be looking at failure. Of course a traffic cop might have an opinion on this. IMO Doesn't make sense to drive around with a reason for them to stop you.
On many occasions it has been those reflectors (and the registration plate) that have stopped me piling into the back of vehicles because the driver didn't think it dark, raining or foggy enough to put their lights on.
Just checked my car using a torch. The bumper reflectors are the only ones on the back of my car. There is no reflective element in the rear light cluster. So definitely illegal to remove them and and a MOT failure.
If you have a dark coloured car parked on a dark street the reflectors are going help prevent cars crashing into your pride and joy.
I have tinted both the reflector and rear light ;)
35C24117-2E8B-433A-A064-68D8D6531247_zps
Edited by stoft
Why not go the whole way and take the bulbs out?
I don't think it's too dark :)
37508035-5E06-441F-8FCD-D8317FAC5C42_zps
The reflectors on the non vRS look much better than the vRS one going straight across the back :-(
Nothing to stop you "blacking out" a section of it.
Thank you for this picture, maybe i will do the same. But i kind of like the rear Lights as they are, the future will tell!
Have you sprayed with toner spray or have you used plastidip? :)
Lights with toner spray and reflectors with vinyl :)
 You might not, the driver who hits you up the backside might disagree.
