Fault code P0299 HELP
Hi All,
I'm hoping you can help me as my garage are now at a loss as to what to do with my car as we've tried most things. I'll list events and replacement parts below:
Car Octavia VRS 56 plate.
Glow plug light comes on and engine goes into safe mode.
This happened off and on over several weeks but not daily.
Garage plugged in and fault code P0299
Checked all connections, pipes, vacuum.
Didn't work.
Had diesel particle light also come on.
New actuator advised but couldn't get one for my turbo. Even tried a repair kit but oh no, can't get that either for mine.
Eventually garage reluctantly replaced the turbo GT1749VC
This didn't solve the problem and glow plug light and engine safe mode happened again.
Garage changed pressure switch and check pipes, connections again.
Drove 100 miles and car started the tale tale 'resistance'. Glow plug light flashing again.
Stopped and car generally is ok for a while but...
Glow plug light flashing again, engine in safe mode and now I have the light on for the control system for exhaust gases.
Car really chuggy (can't think of a better word)
Car recovered from Wiltshire to Wales.
Garage checked everything again and replaced the a vacuum switch that seemed to be 'faulty'. He wasn't sure but ordered a new one to see if mine was failing and there was a difference so replaced mine.
Drove car for 5 minutes and glow plug light back on, engine in safe mode.
Also diesel particle light was on (now off after driving 2,500 revs in 4th gear).
I have no idea if this is relevant. Also I have noticed if you try and keep the revs up the car does 'jolt' sometimes like it's on an elastic band being released.
The garage doesn't know what else to do so I said I'd do some investigation. I have read other threads on here that people have experienced the same.
This really is my last hope.
Edited by sallych
Sorry the fault code is: P0299. Code stated actuator and can't get one for my car - tried everywhere and also a repair kit - Nope not happening.
This is the reason the turbo was replaced
P0299 is a known issue on this vehicle, it required some checks on the turbo. Unfortunately the turbo has been replaced which doesn't bode well
Symptom
The engine warning light illuminates
Fault codes:
P0299
16683
Cause
Worn turbocharger blades
Solutions
Start the engine
Connect the diagnostic tool
Check the inlet manifold pressure
At idle speed
~ 980 mBar
Full load
~ 1520 mBar
Note: The value is too low
Check the turbocharger actuator rod for correct operation
If no fault is found
Stop the engine
Turn the ignition off
Apply and maintain vacuum to the turbocharger blade pneumatic control valve
200 mBar
Use a vacuum pump
Start the engine
At idle speed
~ 980 mBar
Press the accelerator pedal smoothly
If the displayed value is:
Full load
< 1700 mBar
Stop the engine
Check the turbocharger blades for wear
Visual wear indicator
Renew the turbocharger
Turn the ignition on
Delete all the fault codes
Each time you get a warning on the dash (glowplug, engine management, DPF) a fault code is almost always recorded.
Each time the car drops into limp home mode a fault code is almost always recorded.
I suspect there will be more than just the P0299 code at play here.
The occasional jolt you talk about at high revs is the DPF dropping in or out of regeneration mode. Mine did this too.
