Question And Pleadings For Big K (no Hammer Needed)
"ok this morning i sucessfully programmed a flip key to a car that has the other remote on it so it can be done i looked into the prices and according to my machine the keys (both parts) are
Alex - I was thinking about the same thing the other day - still on my list of "i'd like to do that if I can find the money" mods :)
On a similar note, my key is frequently failing to disengage the immobiliser (the car with the key symbol keeps flashing after the ignition is turned on). If I turn off and back on a couple of times it usually works. Is this just a sign of dying batteries in the key, or is it likely to be something more sinister ... ?
nick does this happen with both keys if so the wiring between immobilioser coil reader and immobiliser control unit (in dash) will have to be replaced if the other works fine then the key will need to be replaced hope this helps big k.
Good point - will try the other key
