Octavia ll 1.6tdi Gren Line Coding help after new battery
Hi all.
I am new in the VCDS world, and I am seeking for help to code after changing to new start battery.
My car is Octavia 1.6 tdi Green line 1Z (Face Lift) from 2011, with Start/stop function.
The battery is needs to be changed, so I bought a new Varta E39 AGM 70Ah but not from Skoda.
The old battery is a VW/Varta AGM 68 Ah with following BEM Code:
000915105CC JCB2B0103308R.
But if I am checking for battery info with VCDS, as showed in this video, I can’t see the correct battery info anywhere.
Video: "https://www.youtube.com/watch?v=IJAScg6JrYI"
If I in VCDS use: "61-Battery Regul." and "Coding - 07" I don’t get the active Drop Down menu where I can choose any things, as shown in video.
If I go in through the "19-CAN Gateway - Long Adaptation 0A" I cannot choose "Battery Information / Replacement"
If I manually select "Channel 04" then comes the following battery info until "Stored value":
068 XXX 000915105C (total 18 Digits Inc. spaces)
The mysterious thing about this is that on my VW BEM code label reads:
It's not the same figure….
Can anyone please help me how to code my new battery, if any coding is necessary?
And why can’t I read the correct value from my old battery in VCDS (still mounted)
I will insert my “Auto Scan” down bellow.
Edited by hch
Tuesday,13,December,2016,17:04:31:64536
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 16.8.3.1
Data version: 20161010 DS267.0
www.Ross-Tech.com
VIN: TMBCT61Z2B2122001   License Plate:
Mileage: 161130km-100121mi   Repair Order:
Chassis Type: 1Z (7N0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 61 69 77
VIN: TMBCT61Z2B2122001   Mileage: 161130km-100121miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
69-Trailer -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 NJ    HW: 03L 906 023 JH
   Component: 1,6l R4 CR td H43 9971
   Revision: --H43---    Serial number:
   Coding: 00114014032401080000
   Shop #: WSC 73430 031 00083
   ASAM Dataset: EV_ECM16TDI02103L906023NJ 003010
   ROD: EV_ECM16TDI02103L997557B.rod
   VCID: 7BF474FDF219789AE9-802E
No fault code found.
Readiness: 1000 0000
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
   Component: ESP MK60EC1   H31 0108
   Revision: 00H31001
   Coding: 113B201C092400FC880B04E4901A0051300000
   Shop #: WSC 73430 790 00083
   VCID: 76E265C9C13B25F296-8022
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3T0 820 047 AH    HW: 3T0 820 047 AH
   Component: AC Manuell    H20 0607
   Revision: 00001012
   Coding: 0010000003
   Shop #: WSC 19891 000 1048576
   ASAM Dataset: EV_ACManueBHBVW36X A01010
   ROD: EV_ACManueBHBVW36X_SK35.rod
   VCID: 75E062C5D43D2EEA9F-8020
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 085 H    HW: 1K0 937 085 H
   Component: BCM PQ35  B+  104 0615
   Revision: 00104 AE
   Coding: 40000AB8A005089040100084110000A4430000AE420085605CC4C7000041
   VCID: 34669FC197C777E268-8060
   Subsystem 1 - Part No: 1Z1 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 12021  26  0601
   Coding: 00D7B7
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q6 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2PA617
   Coding: 0020790
   VCID: 3D70BAE5648DB6AA97-8068
   Subsystem 1 - Serial number: 6332MSME5C2153357
   Subsystem 2 - Serial number: 6342MSME5C2144729
   Subsystem 3 - Serial number: 6351HSME2634585CC
   Subsystem 4 - Serial number: 6361HSME26531334
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 1K5 953 521 AG    HW: 5K0 953 569
   Component: LENKS.MODUL   014 0140
   Revision: FF010040    Serial number: 20110213201436
   Coding: 4080140000
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWSXS.rod
   VCID: 72EA59D9A55339D2BA-8026
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 1Z0 920 803 M    HW: 1Z0 920 803 M
   Component: KOMBI         H05 0405
   Serial number: 00000000000000
   Coding: 510A00
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod
   VCID: 3E72BDE9A18BADB28E-806A
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H35 0614
   Revision:   H35       Serial number: 070211F2000788
   Coding: 351302
   Shop #: WSC 00354 204 90352
   VCID: 316896D568D542CA03-8064
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H05 0405
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
   VCID: 6ADA41B98D83F11202-803E
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 3T0 035 686 H    HW: 3T0 035 686 L
   Component: RNS-MID       H26 6270
   Revision: AB001001    Serial number: SKZ6Z7P5960108
   Coding: 00000200020100800000
   Shop #: WSC 01723 013 01313
   VCID: 3B74B4FDBA99B89AA9-806E
   Subsystem 1 - Part No: 3T0 051 859 AP
   Component: EU West V14  8477
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1T0 959 701 AF    HW: 1T0 959 701 AF
   Component: Tuer-SG         009 2119
   Coding: 0131188
   VCID: 7BF474FD3A19789AE9-802E
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 69     3201
   Revision: 00H20000
   VCID: 34669FC157C777E268-8060
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0131188
   VCID: 479CD80D3651EC7A3D-8012
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 7N0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H35 0614
   Coding: 030B185A
   VCID: 71E856D5A85502CA43-8024
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370531277
Address 69: Trailer (J345)       Labels: 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Component: Anhaenger     H09 0100
   Revision: 3A001001    Serial number: 00000140729390
   Coding: 0100000100000000
   VCID: 306E93D163DF4BC20C-8064
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 M    HW: 7P6 035 730 M
   Component: TELEFON       H16 4217
   Revision: 1B001001    Serial number: 00007666716885
   Coding: 0A11000000010110
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3C76B7E1B797BFA2A0-8068
End-------------------------(Elapsed Time: 02:14)--------------------------
Tuesday,13,December,2016,17:56:31:64536
www.Ross-Tech.com
   Revision: 00H31001
   Revision: 00001012
   Coding: 0010000003
   Revision: 00104 AE
   Coding: 00D7B7
   Coding: 0020790
   Coding: 4080140000
   Coding: 510A00
   Coding: 351302
   Coding: 000000
   Coding: 0131188
1 Fault Found:
   Revision: 00H20000
   Coding: 0131188
   Coding: 030B185A
End-------------------------(Elapsed Time: 02:10)--------------------------
its very common on vehicles with battery monitoring systems ,if not done the alternator may not charge the battery fully ,the bosh KTS system we use lets us input battery specs but my ODIS unit uses the coding of an OE battery's , ifound this u tube video witch may help
Edited by patrolman
Every day is a learning day for me too!  Presumably this this only required only for start / stop systems and AGM batteries?
My Skoda Octavia 1.6 tdi Green Line 1Z has start / stop.
I have tried all three methods from the video, but none of them is possible, I don't get  any drop down menu, where I can make any choice..?
Assuming it's a genuine cable, it might be worth posting on the ross-tech forum. If it can be done they should know how :)
Thanks for answers :)
The first cable was not, I've have discarded it now, and has bought a genuine cable today, I'll try again tomorrow and see if it made any difference.
Otherwise I will try on Ross-tech forum when they have accepted my registration, that I have made right now.
So now I managed to get the battery coded.
I do not know if it was due to the old cable, or I just did not find the right menu.
But now I coded it under: 61-battery regulation, 10 Long Coding, Ch 04
Problem solved.
Edited by hch
