OBD Eleven help
I have got my OBD Eleven and it works.
Managed to activate stuff like rear lights on with DRL etc.
A couple which I can't get to work are Static Cornering lights and DRL dimmer with indicators. Is this because my car is maybe missing certain control modules? There are a few items which when I try and add them it says my car doesn't support this. Like High Beam Assist.
Have you reset the cars lighting to factory settings in the infotainment? This sounds counter intuitive but it works.
I have tried that. Even checked in the coding and it all looks active. It's all in German or something and I can't read that.
AFAIK static cornering lights should work. Did you have your lights switched off (not on/auto) before coding/running the app?
