Heated mirror fuse size.
Can someone have a look at their fusebox and tell me what the amperage on fuse 18 is. Mine's missing, stuck a 10 amp in and both mirrors heat up, but I want the correct size fuse in.
Edited by peter3197
should tell you in the manual.
on my VRS MK2 it is a 5 amp, but best to check manual
There are no fuse sizes in the manual or on the diagram on the fusebox cover.
well that's a bit poo :(
someone might come along with an offical diagram but in my MK2 its like this
Fuse Box
Also a corrected RHD drive fuse panel (VRS)
Fuse Panel Correction RHD
5 amp it is, then. Thank you.
Owners manual says No. 18  'mirror heater' 5 amp
Unfortunately, in my owner's manual, it doesn't give the fuse size. 05.11 version.
  • Sponsor
The current flow diagrams for a 2011 car say 5A. :thumbup:
