Boot Size
I haven't got access to my car to check and I need to order some timber today, so I'm hoping someone could tell me from experience if this would fit in my car? I'm getting a large sheet of timber cut into four pieces:
500x1440mm (0.5x1.44m)
310x1440mm
1004x1440mm
540x1440mm
The part in the bold is the one I'm concerned about the most - it's almost 1.5m^2. I'm having to drive to Middlesbrough from Newcastle so I don't want to find out that it won't fit when I get there.
Cheers!
On the Octavia estate, the length when the rear sits are folded 1.6metres, width between the wheel housing arch about 1 metre.
Hope this helps.
Hope this helps.
It's going to be close then!
I can get the largest part down to 1004x902 if I get them to cut it to the actual size of the part.  Should fit...
