rear coil springs
I recently changed the rear coil springs on my M1. Strangely one side had one rubber bush at the bottom of the spring, and the other side had one at the top, neither side had two bushes. Should there be one or two bushes per spring, if one then should it be at the top or bottom please - thanks in anticipation. Mat
1 at the top, probably worth changing while your under there.
Rubber bush at top and like a metal spacer thing at bottom to stop spring rubbing on axle
