The Definitive VCDS List for Fabia MKIII
As promised this is the new list.
It is locked to keep it tidy.
If you have any more to add, PM me and I will include it on the list.
Damo
PS, it goes without saying that all adaptions are done at your own risk, and Briskoda will not be held responsible for any problems that could occur. Always keep a copy of your scan before attempting any coding.
//----------Working on a plate 16 Fabia----------
NEEDLE STAGING
- ECU17 (Instruments)
- Coding
- Byte 1
- Bit 0: enabled (Default: disabled)
LAP TIMER
- Coding
- Byte 1
- Bit 3: enabled (Default: disabled)
HILL HOLD CONTROL
- ECU03 (Brakes)
- Coding
- Byte 22
REFUEL QUANTITY
- Coding
- Byte 10
- Bit 4: enabled (Default: disabled)
STATIC CORNERING LIGHTS THROUGH FOG LIGHTS
- ECU09 (Central electronics)
- Adaptations
//-----Left-----
- "Leuchte12NL LB40"
- "Lichtfunktion B 12"
- Set "Abbiegelicht links" (Default: "nichts")
//-----Right----
- "Leuchte13NL RB3"
- "Lichtfunktion B 13"
- Set "Abbiegelicht rechts" (Default: "nichts")
Coming home/Leaving home for cars without Fog Lights (Using DRL's)
- Adaptations
//-----L-----
- Leuchte 6 ABL LB44
- Light function C6
- Set "Coming Home / Leaving Home active"
- Dimming C6
- Set "0"
- Dimming direction CD6
- Set "minimize"
//-----R-----
- Leuchte 7 ABL RB5
- Light function C7
- Dimming C7
- Set "0"
- Dimming direction CD7
- Set "minimize"
If you have problems with low beams (flashing on and off), then you should do the tweaks in "Leuchte 12NL LB40" and "Leuchte 13NL RB3" instead of "Leuchte 6 ABL LB44" and "Leuchte 7 ABL RB5".
Edited by Damo
Alternative coming home/leaving home for cars without light sensor
I'm not sure, if the lightfunction is named Umfeldbeleuchtung or Umfeldlicht
Controller 09
security access: 31347
Adaption
Leuchte2SL
         Lichtfunktion G2 =  Umfeldbeleuchtung
         Dimmwert GH2 = 10
Leuchte3SL
         Lichtfunktion G3 =  umfeldbeleuchtung
         Dimmwert GH3 = 10
Leuchte4TFL
         Lichtfunktion E4 = Umfeldbeleuchtung
         Dimmwert EF4 = 127
Leuchte5TFL
         Lichtfunktion E5 = Umfeldbeleuchtung
         Dimmwert EF5 = 127
Leuchte20BR
         Lichtfunktion E20 = Umfeldbeleuchtung
         Dimmwert EF20 = 18
Leuchte21BR
         Lichtfunktion E21 = Umfeldbeleuchtung
         Dimmwert EF21 = 18
Leuchte23SL
         Lichtfunktion C23 = Umfeldbeleuchtung
         Dimmwert CD23 = 100
Leuchte24SL
         Lichtfunktion C24 = Umfeldbeleuchtung
         Dimmwert CD24 = 100
Leuchte25KZL
         Lichtfunktion B25 = Umfeldbeleuchtung
Thanks to @djduese for this :thumbup:
Edited by Damo
  • 2 months later...
New one
BOLERO SPLASH SCREEN
- ECU5F (Information electronics)
- Coding
- Byte 18
Logo                 Bit 0        Bit 1       Bit 2
Skoda (Default)   disabled   disabled   disabled
RS                     enabled    disabled   disabled
L&K                   enabled    enabled    disabled
Monte Carlo        enabled    enabled    enabled
Scout                 disabled   enabled    disabled
Greenline            disabled   disabled   enabled
Big thanks to @yankarinRG for finding this out :thumbup:
DRL's fade out when activating the indicator and back in when they are cancelled. As stock they sharply decrease\increase in brightness.
LED DRL DIM WHEN USING INDICATORS
- Adaptations
//-----Left-----
- "Leuchte2SL VLB22 "
- "Lichtfunktion C 2"
- Set "BlinkenlinksRampe" (Default: "Blinken links aktiv")
//-----Right----
- "Leuchte3SL VRB36"
- "Lichtfunktion C 3"
- Set "BlinkenrechtsRampe" (Default: "Blinken rechts aktiv")
 Thanks again to @yankarinRG for sharing this :thumbup:
Edited by Damo
  • 3 years later...
As Damo is no longer around to update this, @JGrindel has started a new thread which will incorporate and take over from this one.
Guest
