Squeaky noise at 30mph..
Sometimes whle travelling at a steady 30mph I get a squeaking noise coming from the front passenger side of the car. It's coming from the wheel somewhere but not too sure what it could be.
When accelerating from that speed it seems to disappear but always comes back sometime later when going at 30 again. Any ideas?
I've also got squeaky brakes if that helps but they only squeak at very slight pressures on the brakes (so slight that its not actually slowing the car down).
Might be the pads slightly rubing the disc - I had that problem on my Corsa for a few hundred miles.
Any fix I can do myself?
it's the hamster from the turbo.
When it happened on my Corsa Vauxhall said there are 2 options, either wait for that part of the pad to wear away or change the pads, and it could happen again anyway.
What annoyed me more than anything is that it was worse when I turned a corner, but after a few hundred miles the pad wore down a bit and it stopped.
