Boot light
The boot light in the Roomster stays on all the time when the boot is open.  Is there any (relatively easy) way to modify this so you can switch it on and off as required, like all the other door lights in the car?
Thanks,
Hi DeeGee, do you drive a lot with the boot open ? Ha Ha. You must do a lot with the boot open, maybe your job. Two ways I can see, (1) take the bulb out, or, (2) you can prise the holder out so you can get to the wire's and splice a switch in.
