VCDS help
nugbuv
You might be better off asking this question on the VCDS forum.  The procedure to get the Maxidot to display mph has been discussed a number of times on this (ie Yeti Mk1) forum: a search should turn it up if you don't have it to hand.
Thanks. Although, helpfully, it was on this forum that I discovered what a VCDS is and the fact that it could work magic – it's not a discussion I'm after; it's a magician.
If you were to have looked at the link @ejstubbs had posted you might have noticed these two threads:
https://www.briskoda.net/forums/topic/262215-list-of-vcds-owners-previously-known-as-vag-com/
https://www.briskoda.net/forums/topic/224376-vcds-owners-map/
Either will help find local VCDS owners (or magicians) :)
