upgrade software STEERING MODULE 44
it is possible to upgrade :
Adresse 44: Direction assistée        Labels: 1Kx-909-14x-44.clb
   No. pièce: 1K0 909 144 M
   Pièce: EPS_ZFLS Kl. 69     3201
   Révision: 00H20000
   No. Atelier: WSC 73430 790 00088
   VCID: 3467EA3957431CBE401-8061
 by the soft : 1K0909144R soft 3501
Is there that already tried this update ? the new firmware in below :
lh0013501.sgo
Skoda_Oct_RS.sgo
lh0023305.sgo
I've done mine, originally:
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 69     3201
Now:
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 69     3501
There are a few different steering curves to choose from, I tried the TT RS for a while but changed back to 69 as I didn't feel it made a significant difference to my normal drive.
Thank you langers2k
, is this obliged to do the 1 file lh0023305.sgo to flash my module? Or the following order is required:
1 lh0023305.sgo
2 lh0013501.sgo
3 Skoda_Oct_RS.sgo
Or it is possible to directly make the 2nd file lh0013501.sgo then the
steering curves Skoda_Oct_RS.sgo?
Is there a change after switching from update 3201 to 35?
After flashing, how to clear the faults of module 44? Please in detail since I am interested in flashing my module 44 and are there any faults in module Address 03: ABS brakes (J104)?
Have you tried the Skoda_Oct_RS.sgo curve? It is better than 69?
Thank you
I think on the 1K0 909 144 M it's only necessary to do that last two. I did all three as that's what the instructions suggested at the time.
Make a note of the coding and adaption channels of 44: Steering assist before flashing and set them correctly afterwards. The basic settings procedure is covered here: http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Steering_Assist
If I did have any errors in 03: ABS, then I just cleared them. If you're worried, make a note of the coding and adaption channels before flashing.
Never tried the RS curve, only the TT RS and stock curves :)
  what is the new in this last firmware 3501? any change in steering after switching from update 3201 to 3501? For the mke it is obligatorily necessary the soft 3501, it is run under soft3201?
I can flasher the three files with Vag can pro VCP ( i can send the 69 curve with VCP)?
  • 3 months later...
4 hours ago, 1Sinister1 said:
pls, where i can find and download charakteristic curve for Gen III. power steering? I found only DB http://tech.gtx.su/vag/?hide_gen_2=1
Got an autoscan for the car you need this for and do you know which curve you need?
Adresa 44: Posilovač řízení        Labely: SVO\1Kx-909-14x-44.clb
   Řídící jednotka: 1K0 909 144 P
   Díl: EPS_ZFLS Kl. 239    3305
   Revize: 00H22000
   Dílna #: WSC 01357 011 00200
   VCID: 37775BDF462998FA30-8062
This is a scan from my Golf 6 R-line. Currently there is a curve from Audi TT RS. On place is steering perfect, but I'm looking for a curve, where while driving is not too heavy.
I sloved my problem but i have one last question. Can I upload curve 8j0 into my ECU? For example, I have 1K0 909 144 P. Can I use file v074N2418J0___Lenkung_Reibung.sgo??
THX guy
  • 1 year later...
   Révision: 00H20000
lh0013501.sgo
Skoda_Oct_RS.sgo
lh0023305.sgo
@25recep - not sure what your question is?
  • 2 years later...
hi mate, ive got a vcp pro cable and software on the way,  i need to flash the vrs curve onto my recon rack ive just installed (gen2), are the files above what i need or do you know where i can download the correct ones? any help would be appreciated
cheers
luke
Edited by lukegcorrida
